My jumper cables have a volt meter on them and it showed the same for my cruiser as my daily at 12.5
Cleaned them up with a tooth brush and paper towel the reattached so I don’t see how that could be the case.
Will get the battery checked tomorrow.
Thanks for the input! Good to know my electrical isn’t fried after getting it to turn over today
As just mentioned... 12v in and of itself proves nothing about your battery or your connections.
A tooth brush and paper rowel are definitely not in Toyota's "Special Tool" list.
Wire brush, sand paper, steel wool will clean those surfaces bright and shiny. THAT is wnat you need. Also check to see if the surfaces are badly pitted. A bit of hydrogen peroxide from your first aid kit, or a bit of Coke from the bottle will eat away any crusty deposits too.
What sort of cable ends do you have? If you have those cheap parts store replacement ends that clamp onto the end of the cable... make damn sure that connection is good and is clean too.
This might not be your problem at all. But it is just about #1 on the things that you want to check before you dive deeper looking for other problems that might not even exist.
Mark...
