No more position lights
Website
transworldexpedition.com
Hi all,
Thought i'll check with you guys if you have any idea what's going on. Tonight suddenly, I have no more position lights, sidelights, tail lights or plate lights. My medium and high beam work fine, but still no back light. My dashboard light is out as well. So far, i noticed only one dead fuse, TAIL in the dashboard. Tried to change it, but the new fuse blew immediately. Anyhow, all the problems cant come from just this one right? Any idea where i should look first?
Thanks!
99% of the time, the ground of the new radio is installed to the dimmer wire in the dash "because it measures like a ground when the dimmer lights are off.
It blows the dash light fuse at a minimum, the parking light fuse the rest of the time.
Nic...
The tail light fuse controls quite a few circuits ; 4 I think. I put together a chart that may help. It assumes u have the right books. Off the top of my head, u can have a shorted lamp (parking, for example) that will blow the TAIL fuse. This is one area where Toyota did not think things thru.
FZJ80 FUSE CHART GUIDE
I had the same exact them happen to me last week while driving down the freeway at night. I called a 24 hour part store and did alot of looking online (I don't know much about cars and have no user manual). Come to find it it is the tail light relay. $33.98 later and I was all fixed. I did have to take it to my mechanic to put it in because I was not sure which relay to pull. It is located under the kick plate (I think that is what is called) on the driver side and I can tell you wich one it is (there is 6 down there that look exactally the same).
