No more cold idle?
Maine
Hi guys, I have had my rig since new. Tonight i went out to start my rig after it sat overnight and no cold idle? This is the very first time in 12 years of ownership that the 80 did not go into cold idle. Should i be looking for something? By the way it's freezing outside. Thanks:confused:
Probably frozen....
Idle air control valve. There is a test for it in the FSM
BTW what year is your rig?
Actually, for incorrect first idle the 1993 fsm suggests to check in this order:
1 Accelerator pedal link.
2 ECT sensor circuit.
3 IAC valve.
4 ECM
So you have 650ish RPM all the time at idle?
Dave
Do you have the FSM?
Mogas, My rig has always idled high since new, hence the shock of going outside in freezing weather and normal idle. Thanks for your input though i will try and check the stuff you mentioned. :beer:
PM me your email address and I'll email you the appropriate sections.
i am assuming you havent done anything on it recently...
TrueDat... If you have been working around the throttle body or ECT sensor, (Oil filter change) you may have bumped a wire.
The IAC on other model Toyotas are known to be problematic. This is especially true on Camrys. I haven't needed to pull then apart but that is the recommendation on the other vehicles. They get gummed up and sticky and stop doing their job. They mostly cause a high idle however.
It's common to jump on the electrical side of these types of problems but the solutions are usually on the mechanical side.
Thanks for the email MoGas, I cleaned the TB about a week ago, so it has been running fine until tonight. Sorry for the delay guys as i have been re-checking my work from last week. :confused:
Iv'e had to clean my TB when I lose my cold idle. Did you take it apart to clean or just spray and wipe?
