No joy in mudville
Anchorage, AK
A couple weeks ago I went to start the 80 (1996) and she fired, then died and would not restart. I had to run, and am just now getting time to troubleshoot.
I checked spark and that seems fine. I went through the emergency starting procedures thread (Emergency Troubleshooting Procedures - FAQ Item (Recommend Keeping Copy in Truck)) and still don't have an answer. I have a check engine light, I get fuel from the fuel pressure regulator when I pull the hose, efi fuse is good, and I have swapped the efi relay with no change. No codes found when I try to read the OBD 2 with the scanguage.
Just checked compression and I have 70, 95, 89, 62, 90, 100. The 62 is pretty concerning, but I don't remember what compression numbers are supposed to be.
I'm guessing burnt valve. Any other troubleshooting I can do without tearing too far into it?
62, and 70 are ugly, like its time to do something different ugly. Pour a LITTLE bit of oil through the spark plug hole into the cylinder and see if it comes up. Thatd tell you if its a piston/ring/cylinder issue or something else... 90 psi is runnable but you shouldnt have such a swing between cylinders
Will it run on ether? Got oil? Getting air? Could be timing related but your two low comp cylinders are definitely not helping. Should still run real s***ty like though.
@maxamillion2345 I understand your thoughts and concerns about the compression numbers, but I wouldn't be concerened there either. All gauges read differently and there Is no real way to know how methodical the OP is being. Some of us will count the number of compression cycles as the gauge fluctuates and others will just do a verbal count meaning they may not get the same number of compression strokes per reading. I've known a number of people that did it that way and their engine was fine. However, if the OP did the compression and counted the compression cycles evenly and on a tendered battery then there is definite cause for concern and adding a tablespoon or cap of oil to the cylinder and retesting is a definite must.
Also, the compression test for these is SUPPOSED to be run when hot. I ran mine after it had sat for a month and I had numbers like that. Scared the hell out of me, but once I read into it, it's no big deal. Those numbers don't mean anything after sitting like that.
Also, if it was running, then died, a burned valve happens over time, and not "suddenly". A catastrophic failure happens with a lot of noise or severe stoppage.
Take the time to diagnose.
Air, Fuel, Spark.
Right now, my money is on the fusible links.
Engines need "Suck, Squish, Bang, and Blow" to survive.
Does it turn over? when it is turning over do you hear any unusual noises?
Do you have fuel pressure? is the fuel pump coming online? you said you had fuel coming out.
This to me sounds electrical. Could be fusible links, melted/damaged harness, or a ground.
Have you tried to jump start it? could you have a bad cell in your battery?
Well, good news. You guys are awesome and my compression testing needs work.
Battery was low last night when I did compression tests, and I pushed it into the shop. As I was getting the battery charger hooked up, I noticed the negative terminal was loose. Tightened that and let it charge overnight.
I added 1/2 tablespoon of oil to cylinder 1, and got a reading of 129. That seemed like a huge improvement over 70, so I retested all the others without adding oil. I ended up with 120, 150, 120, 160, 119. That was such a huge difference, I put plugs back in and tried it. It fired, ran really rough for about 45 seconds, then cleaned up and ran like always.
So... I don't know WTF it was, but she is running again...
