No Interior Lights
Chugiak, Alaska
Well, I'm stumped, I still don't have interior lights. I've replaced two door sensors and cleaned the others. They seem to be working. But I still don't have interior lights and the door open light is on. Any suggestions on where to start testing next?
Nope, checked that first.
Are you getting +12 to the dome fuse?
Are you getting +12 to the door switches?
Give a little detail about when this happened and what was done prior to this happening.
The interior light circuit is pretty simple, but there are 2 sets of diodes that no one knows about. On my 91 they are located above where the driver's left foot would rest, taped to the wiring harness. They look like small white plastic plugs at the end of a connector. Took me forever to find them and I wasn't able to source the replacement. But I didn't look real hard either.
One set for the front doors, one for the rear, so I doubt this is the problem.
Check that you don't have the common problem of the wiring tha goes from the rear hatch door into the car at the top of the roof on the left corner of the car.
It is common that the wiring goes bad there - sometimes by tapping the headliner up in that corner, you can see the dome lights flash or play up - it's like a loose connection.
My problem was the connector - a clean up fixed it - others have had broken wires and bad ground right next to the connector...
You will have to remove the liner at the back of the car to get to the wires... not that much of a big deal to fix - but this bad eartch cause all kinds of weird problems from dome lights to the heater fan to the rear wiper playing up.
I bought the rig salvaged and the body shop had to repair the drivers side doors and rear quarter. The lights didn't work when I got it, not a big deal during the Alaskan summer. I haven't pulled out the tester yet, but the only time it worked was when my wife opened the rear hatch, then it didn't work again. Thanks for the tip about the rear door wires, I've got a hunch that is it.
I apparently have a short in my wiring somewhere near the sockets themselves. Sometimes my lights work, sometimes they dont. When they dont, I can normally pound on the light itself with my palm and it will come on (just the front one - I have to pound on the back one if I want it to work).
Sometimes they will work the next time I open the door, sometimes it wont.
Remove the plastic lenses and tighten the mounting screws.
