No heat from heater.
North Las Vegas, NV
So here is the deal my sister has a 89 mini 4x4 4cyl 5spd and the truck as no heat from the heater. I have checked all the normal stuff and it seams to be ok and collent seems to be making it to the heater core. I am out of ideas and I am sure that I am not the first to come across this any help would be great.
There is also a flapper door that diverts the air through or around the heater core. Move the hot-cold selector back and forth, you should hear a "thwump" under the pass side foot well. Have you checked to make sure that the heater valve is opening? It's on the firewall in the engine compartment.
If you pull the glovebox down you may see how to get into the heater/cooling ducts... Check the FAQ thread here, I did a thread on replacing the heater core, and it has lots of pics of the process. You should not need to get in that deep, but it'll help you figure how far you have to go.
