No Headlights
Rockingham NC
For a week or so, my 24V BJ70 only had the right side headlight. Last night neither worked at all. No low beams and no high beams. All other lights function perfectly fine when switched on. HELP!
Do you have power at the head light sockets? Its common for both globes to go out close to each other. I always replace both when one goes. The headlight are not very well earthed and this causes problems as well.
Not the ground, not the fuses, not the lamps. Appears to be the dimmer relay. It was making a buzzing noise and I whacked it a few times and the lights came on. So I guess I'll do a parts search for that relay.
85926-60010
08/1980-09/1984TOYOTA LAND CRUISERBJ42,FJ4084-01: SWITCH & RELAY & COMPUTER
11/1984-06/1987TOYOTA LAND CRUISERBJ7084-01: SWITCH & RELAY & COMPUTER
03/1969-06/1980TOYOTA LAND CRUISERBJ40,FJ4*,5584-01: SWITCH & RELAY & COMPUTER
08/1980-07/1987TOYOTA LAND CRUISERBJ60,HJ60,FJ6*84-01: SWITCH & RELAY & COMPUTER
Searched around in Australia and UAE; there is nothing available.
Contact Beno or one of the other forum LC Guru's
You might consider taking apart the relay and see if the relay can be repaired internally....
