No Hazard flash on 2017
SoCA
I’m hoping that someone can share some info that can help me troubleshoot an issue with my wife’s GX460.
The hazard warning flasher doesn’t work (no response to depressing the appropriate push button).
I‘d read somewhere that a loose connector at the back of the radio was the issue with one owner. I’d hate to take the radio out or otherwise access the rear if it’s not the fix for our GX.
Thanks in advance,
John
Do your turn signals work?
If not, then it's probably your flasher unit which should be a quick, simple and cheap fix.
Turn signals work fine. Just the hazard flasher doesn’t.
Well... So much for a possible "... quick,simple and cheap fix."
Hope you figure it out!
