No fuel pump power
Colorado
Got this 93 a few months ago, and have driven it some, but not a lot. Got it while in Iraq, and have been playing with it since I got back a little over a month ago.
Loaded it on the trailer to go wheeling, had to pay out the winch a little (the only time I had ever even checked it to see if it worked) Cruiser was not running that I can remember when I payed the winch out but could have been.
I get to the trail-head about 115 miles away, un-chain it, hop in to start it and nothing! I checked all the fuses, etc and then chained it back up and headed home before the J**p guys on the trail already came back and saw that I must have apparently left the key at home and have to go get it, LOL.
All fuses pulled, checked. As well as the fusible links.
It is getting spark on all cylinders. Initially I was not getting power at the fuel pump and jumped the B+ and FP at the Diag connector. It then got power up to the top of the pump, but no fuel. So I figure the pump is bad, and order one from CDan. Also ordered a relay, and the EFI relay just in case.
I had swapped the relay and EFI relay out of the other Cruiser in to it as well as putting the ones out of the 93 in the 96 and they were all good, but still no fuel.
Get the new pump, change it, get ready to back it out of the garage and nothing!
Still same thing, power at the top only when jumped, and no fuel.
Pulled it back out, had a little arcing on the + side, but not bad enough to not get juice. The old pump as well as the new one work when given power. I have goon continuity from the top of the pump mounting plate down to the pump.
Today I will continue checking continuity between everything. The Circuit Opening Relay checks good as per the FSM.
The CEL on the dash comes on as it should, and as said prior, it turns over well and gets spark.
Where is the VAF Meter fuel pump switch and could it be not working? I will find that today. It looks like it gives one of the realy coils in the Ciruit Opening Relay a ground.
Could I have toasted the ECM when I payed out the winch???
Any ideas?
Any ideas?
When you say no fuel is that before or after fuel filter ?
Is it possible that filter is clogged?
If I followed your post right, the pump works out of the tank, but not installed. A very common problem with pump-in-tank systems is the tank Ground gets messed up. Have you tried running wires directly between the battery and the fuel pump in the truck to make sure it works in the truck? Pull the connector off of the top of the pump and clamp on a postive and negitive wire onto the pump connectors. Once your two jumper wires are connected to the pump, touch the other ends to the battery. Do it this way so that the intial arch/spark is at the battery and not on top of your gas tank. :hillbilly:
I was trying to complicate things!
Was searching threads with similar problems and ran across this: https://forum.ih8mud.com/80-series-tech/228405-rth-crank-no-start-grrrr.html
It also just happens to be the same 80 that I currently own and am referring to.
I could tell when I started troubleshooting it, that it had been checked and when I pulled the pump I saw the shrink tubing.
All is well now!
All is well now!
Meaning that you replaced the connector and all the wires or re-did the clean & crimp routine, or ?? Any pics? There was another guy having a similar problem after getting an oil change at Jiffy Lube. Last I heard he hasn't determined the exact cause though he took it to a Toyota dealer for repair.
-B-
I ordered the bracket with power and ground wires with connector from CDan.
I will take the old bracket and pump, re-wire it and have a spare.
I didn't want to re-do the clean and crimp as it had been done once already. The + connector at the end of the wire was really weak, cracked, and just plain looked fubared.
I am surprised that it is so hard to get that connector and/or a pigtail for the pump. Would be much easier/ cheaper to just replace the pigtail versus the whole pump bracket. As I think has been mentioned before, it is usually not the pump that is bad.
I also replaced the relay and EFI relay also. Wanted to have spares as with two 80's with 246k and 170k I am sure I might have a problem like this again. Or at best can help the next person that I see with the same problem.
Thanks for the follow-up.
-B-
