No engine temp in gauge cluster
FDo5g
GOLD Star
USA, Central Virginia
I don’t get any readings from my instrument cluster re: engine temperature. What’s more, I seem to have a YG wire dangling in my engine compartment, and cannot seem to find a temp sending unit anywhere near the thermostat housing. Am I correct in interpreting that the temp sending unit is just missing?
not sure what engine you have, but you need a temp gauge. the yg wire does not look factory. the temp sender is usually in the housing below the thermostat, sometimes a second sensor is above the thermostat too. And/or a sensor is placed on the top of the head at the front where the water channel is which leads to your cabin heater. Probably some fiddlin has gone on with pvo.
Perhaps the easiest for now is an aftermarket temp sensor, there are many to choose from. I use engine guard watchdog, it bolts directly to the head, very accurate, easy to install, love it. I use it in conjuction with the ome gauge but the ome gauges can tend to fail or the earths oxidise/corrode over the 30+ years.
This loop of hose is odd.. One of those ports would almost certainly be a temp sender port.
