no drive with CDL off
New Zealand. Christchurch
Hey guys I've got a factory triple diff locked 80 that has Manuel front hubs fitted but not the spool in transfer case. The old owner told me he used to put the front hubs in free and switch on the CDL to run in 2wd well towing so I've done that and driven around for awhile but now I can't go back to full time 4wd.
With the front hubs locked and CDL OFF I have no drive ( front driveshaft spins)
With the front hubs free and CDL On I have no drive ( front driveshaft spins )
Have I blown something? Cv? hub?
pretty much have no drive unless CDL in engaged
If the CDL locks and you have no drive then it would indicate that you have a problem both in the front and rear or a problem within the transfer case. Are you able to lock either the front or rear diffs?
oops sorry mate I diddnt read the question properly. With Hubs locked and CDL On I have drive
If I'm following you correctly then it appears your transfer and rear is OK. What were you doing when the failure occurred? I don't see any advantage to running hubs if your not installing a spool in the transfer. There would also be no advantage to going to 2WD for towing without the spool as well. If one of the hubs is broken I would switch back to regular drive plates being the best and cheapest solution. If it is a broken axle or birfield then there is not an option and must be repaired if you want to ever run 4WD safely.
i have no idea when it happened lol. Thanks for your advice I'll take off the hubs to investigate further
Jack up the front axle with the CDL engaged and hubs locked. See if one wheel spins freely. If so, then that is the offending hub.
