No CEL. Help
Lubbock Texas
93 fzj, 1 fzfe. No CEL on the dash, with key on. Pulled the dash, bulb ohms out good, switched with a known working bulb, still doesnt light up. Engine runs and idles fine. Just no CEL. I don't have wiring diagram, so does anyone know how to chase this down?
Do you have voltage to the light? Try jumping pins E1 and TE1 of the diagnostic connector under the hood at passenger side firewall. I've never heard his problem before.
Search "instrument cluster removal", there is a thread on here with a video that helps a lot. Mine turned out to be an unconnected plug, but I had recently pulled the motor, so it seems to me if your light is out, and the engine starts, then you have a bulb out. Once you have the dash cluster out, you can use a flash light to determine which space is the CEL. Its a pretty easy job, just take your time, the dash clips can be fragile. Good luck.
