No CDL light or ABS light
The Land of Frank Rizzo
Greetings,
Recently installed the CDL on the 80 (no 7 pin yet) and when I put the truck in 4 Low, I got no lights. The CDL dash icon did not light up and the ABS light did not light up. The truck does go into 4low when the transfer case is shifted to low.
Recent history on the truck is that I just got done installing 2 locked axles on the truck, the harnesses from the axle lockers have not been installed yet, but all of the other stuff is there (ECU, Switches). Would this have any bearing on the CDL and ABS light not illuminating?
Any ideas?
Thanks,
John
Bueller, B ue ll er, Bue llerrrrr..............
When you say, "Recently installed the CDL..." I take it you mean the dash switch? If so, have you tried locking the centre diff with the switch while in high range?
Yes the dash switch, I tried in high range, low range, L1, L2 and I think everything else in between. I thought that maybe the light burned out or was not installed, but Dan told me the light is present in the dash even though your 80 did not have that switch installed at the factory. I have never seen that light illuminate at all, at start up, shut down, ACC on or anything else for matter. I have seen the diff lock lights light up as I start the engine, along with the ABS light. Is there anyway to test that bulb?
try going into low range, and turning the wheel on a non slippery surface to see if you get binding. If you get binding, you're locked up, if you don't you're open. Cheers!
I'll bet, like my truck, the switch that screws into the top of the transfer case just in front of the CDL motor is stuffed. The guy I bought the truck off never put it in CDL or low range, so both switches have either jammed up or gummed up. I gotta pull them and cycle them a few times with WD 40 or similar. I read thread once where a guy pushed about 200mA load through the switch (on a test bench) and cycled it a few times to clear the contacts and it seemed to work for him. My CDL and low range work, just got no lights.Cheers,Alex
I had the same issue. The previous owner never used low range. So when I put it in LO both lights (ABS and CDL) did NOT light up.
I didn't have to remove anything at all. I just worked between HI an LO for maybe a hundred times and finally it worked. At first it took a long time to lock, then it locked fast but irregularly, and finally it would lock and unlock without any problems at all.
So my guess is that your mechanism is also stuck and you will have to switch the CDL switch on and off at least 50 times. It's better done with the engine running as the motor receives a higher voltage and has more power. So my proposal is the following... Whenever you have to drive somewhere keep on clicking the CDL switch. Do it at slow speeds (20-30MPH) and on a straight road. One hand on the steering wheel and the other on the CDL switch. 10 seconds on, 10 seconds off, etc.
Thank you for all the helpful information, I will try out what XR & MikePl said to do and I will post the results tomorrow.
Have good weekend!
Have good weekend!
Did your CDL start locking?
My locking setup is stock; I get binding of the wheels if I pull the Tcase lever into L, but no lights come on in the instrument cluster,
so I figure the CDL is locked. Not sure about the lights; why they do not come on?
(Ditto with others; I now just get the blinking lights when I turn the rotary dial for R and F to lock.)
I found these threads because mine (center diff) wasn't locking. After about 20-30 times of putting it in low did it finally come on. about 10 more times to have it come on everytime and instantly.
Thanks for the info!
Only real update I have is that I did the High-to-Low and Low-to-High trick about 50 times and the only result I got was that it's super easy to go from High-to-Low and Low-to-High.
I got the front e-locker harness from Dan and hooked it up last weekend and tried again and I got nothing. No CDL light.
When I moved the rotory switch to the front locker I got the blinking lights, consequently, my rear locker does not have the harness installed and I would expect the light to blink for that locker because there's nothing to work the actuator and the ECU is telling you that the locker is not locked.
I think the switch on the transmission is toast, however, back in the spring when I would move the transfer case fron high to low I would get the ABS light to illuminate and NO CDL light. Now I don't get either light, why this happening I don't know.
It is one of the following:
CDL light Burned Out
Bad CDL Switch on Transmission
Transmission ECU - doubtful, everything else is working just fine
And that's all I can think of right now, its been a long day.
If you guys can think of anything else, post it - I am going to F around with the truck tomorrow morning and if anything happens I'll let you know.
John
Mine too is now working !!! I started pulling the transfer into low every night and letting the car sit overnight in low. And now, lo-and-behold, it works every time, the orange 'diff-lock' light comes on every time, whether I use the CDL switch or pull it into low.Only one other question !! Should I have any lights for 'low', or is it just "diff-lock" ???Cheers,Alex.
Do the jumper trick on the transfer case indicator switch and see if your lights come on. Worked for me which indicated a bad switch. I actuated it a few times by hand and cleaned it off and it started working again.
I am still trying to find this "switch" on the transmission. Once I find that bastard it's "Game On"! I know it is the source of my angst and once I find it and remove it, I'm hitting the speed dial for CDan and it's over - finally.
I have not tried leaving it Lo over night, Christmas is right around the corner - so who knows?
Does anyone know CDans office hours through the Holiday?
Let me be clear in this statement .. not my case ( coz Mines are Part Time both ) but a mate recently buy a 97 80 series with aftermarket front hubs ..
I thought aren't the HF2AV .. it looks more have the HF2A no CDL switch. It means if you are driving in H with front hubs locked .. you are in full time ( but no diferentiation in the t-case ) .
Fact .. I'm not clear if the CDL swith ( as a feature ) are only for HF2AV with visco coupling ..
