No audio on the left side
Dayton,oh
Hey guys, I recently swapped out my OEM Head unit for another OEM head unit and now I have no sound on the left side. I am almost positive it worked when I had the dash apart. could this be a amp issue?
Check your speaker connections, at the harness junctions in the footwells, for continuity (easier than pulling the door cards off). If that's good, pull the dash and check the connection at the head unit.
The EWD has the wiring colors for the audio system, as well as the locations of all the intermediate splice joints in the harness. It's in the Resources section if you don't have it already.
It's unlikely that your amp died at the same time you swapped the head unit. Does the other one work? Why did you replace it?
My of digital dash was out and the sound completely stopped working on that one. Plugged in this one and the sound immediately worked and was much better.
Give @Engineer8000 a shout; he might be able to fix your OEM unit.
