This is a replacement single diaphragm vacuum advancer for 09/77 through 07/80 2F electronic distributors. Applications include:
1) '78 2F Federal spec vacuum retard and advance distributors - replace advancers that have failed diaphragms.
2) '78 2F California spec vacuum retard distributors - convert distributors to vacuum advance.
3) '78 2F high altitude spec vacuum advance distributors - replace advancers that have failed diaphragms.
4) '79 and '80 2F dual vacuum advance distributors - replace advancers that have failed diaphragms. Only for earlier Land Cruisers without the provisions for high altitude compensation (HAC), or for those living at low altitudes where HAC isn't needed.
The vacuum advance curve is very similar to the curve for the 09/77 through 01/79 high altitude spec advancers and Federal spec advancer main diaphragms. Advance begins at 3.94" Hg (100mm Hg), the same as the NLA 2F high altitude spec advancer (Part Number 19220-61110). The vacuum advance upper stop limit can be set by adjusting the position of the two locking nuts on the actuator rod. Installation requires drilling out the tapped blind hole used to secure the original advancer to the distributor housing. No other modifications are required.
I have a limited supply available for $60 each shipped.
