Nitto tire presure??
Austin, TX
I got 4 new 285's and it's looking great and filling the tire well nicely. I am running 32 psi right now and ride seems to be comfortable. My question is how low can you go in Nitto's without damaging the tire and what's the best psi to run in trails in Moab. 15?? 18??
I got the Slee step sliders as well. Pictures will come in the evening
I will be in Moab on from 4th of sep to 8th of sep. with another stock 80 LC . Any adivse on things to do and not to do in a 100.
Thanks in advance
I run 38-40psi on the pavement and they do fine. As far as offroad, I've aired down to 15-20psi for 400+ miles in Death Valley and they did awesome.
Because you have gone from a P metric to LT tire, you need to run your road pressure at 8-10 psi above the manufactures recommendation.
Thanks in advance
I run the same size tire and run 45psi on the road loaded and have excellent results at 15psi off road.
My 285 Revos run very nicely at 38 psi. The 38 psi was calculated by a tire engineer at Bridgestone for the Revo/100 combo and then field tested by me. A good place to start at least.
I did run at 40psi initially but the tire was very hard and ride was rough. It was like hitting a solid rock when going over parking lot spped bumps. So I reduce the air to 32 and it seems ok to me. Will it damage the tire in the long run?
But tires may be different from each brand even though they are the same size. I will try and see how 38psi would work for me. Thanks
Ok Now I know the bottem line. 15 psi. So I can run in between 15-20 depend on the situation. :cheers:
Pulled from another forum... Here's an interesting method. I have yet to try it though.
I worked for Michelin Tire Corporation for 7 years and Yokohama Tire Corporation for 11 years. I have given numerous tire seminars on tire maintenance and especially how to determine the correct tire pressures. So here goes.
The pressure on the sidewall of the tire is the maximum pressure at the published load at approximately 55 mph. (The speed can vary somewhat but it is not important for our discussion).
The air pressure is required to support the load that the tire must carry in such a manner that the tire flexes at the designed place on the sidewall of the tire.
If the load on the tire changes then the air pressure should change accordingly to keep the tire flexing at the proper place.
The reason for correct air pressure is to prevent the tire from overheating. It was put together with heat and it will come apart the same way. An under inflated tire will eventually self destruct due to excessive heat build up. An over inflated tire will ride harshly and be more likely to burst upon impact. Sorry for the long explanation but here is the bottom line.
To determine the correct air pressure, check the pressure when the tire is cold. Run the tire for several miles at highway speed. Stop and immediately check the air pressue in the tire. It should be higher than we cold but no more than 10% higher.
Now here is the hard to believe part. If the pressure is more than 10% higher you must ADD AIR and test again. For example if you start with 50 psi cold. If the pressure is 60 when hot, you have exceeded the (10%) in this case, 55 psi maximum safe heat build up pressure. You must ADD AIR. In this case I would add 5 psi which would take the tire to 65 psi when hot. After you run the tire again you will find the pressure to actually drop because the tire will run cooler. The heat build up causes the tire pressure to increase when under inflated.
On the other hand, if the 50 psi cold pressure does not change when hot. You have more air than needed. You can remove 5 psi or so and test again when they return to cold. Like the next trip you take.
So a fully loaded rig will require more air in the tires than one with empty tanks and a light load on board. Always error on the side of over inflation. Thus the maximum sidewall pressure indicated on the tire is usually used. It usually is more than needed. Each axle has its own requirement based upon the load on that axle.
So how do I get a 2 Rivet rating? Does this long explanation help or hurt?
That is why Toyota specs P metric tires instead of LT tires, they ride better. 32psi puts the tires below the required load rating and and will result in reduced tire life.
Here is a link to a rather lengthy explanation I posted and the following discussion about pressures when converting from P metric to LT tires.
https://forum.ih8mud.com/showthread.php?t=111671
I agree that the best pressure may be a bit different for a different make of tire. But since they are similar in size (285) and class (LT) it would be a good place to start. Then adjust the pressure using some of the other tests.
- business card test
- wet "footprint test"
- chalk line / shoe shine test
- pressure increase test listed above
Revo pressure thread with info on how to do some of these tests
Ideally you should get a load table for the tire and then set pressure based on the weight borne on each tire. This weight is basically GVWR divided by four on the 100 since the front/rear weight balance is very even.
Use an electronic gauge and the same one every time for consistency.
Remember that LT tires run harder so don't lower the pressure until they feel the same as a P tire. You'll end up way too low.
