Automotive fuses are rated 32 volts, because they are used in both 12 volt and 24 volt systems.
http://www.optifuse.com/fuses-auto-blade-reg-apr.php
So a 10 amp fuse will blow at 10 amps x 32 volts = 320 watt load. A 12 volt alternator puts out 13.5 - 14.5 volts. So assuming a 14.5 volt circuit voltage, then a 10 amp automotive fuse will blow at 22 amps, which is higher than most would expect.
For general circuits a 135% fuse rating is recommended and for an electric motor circuit 175%, due to the high starting load.
The 3/4 hp Puma draws 560 watts. So a 12 volt rig with a 14.5 volt alternator - the Puma should draw about 38 amps at that voltage. At the 32 v a fuse rating - a 30 amp fuse would handle 960 watts, which exceeds the 560 watt load by 70%.
I have a 40 amp circuit breaker fro my Puma, but I also have a inverter on that 6 gauge AWG circuit.
slowandsteady BJ said:Good meeting.
We planned a Xmas tree run for the first weekend in Dec. Sat the 8th (I believe).
There were some exciting fuse rating debates....
Home heating solutions.....
Sand blasting in cardboard boxes.....
We might have talked a bit about Cruisers in there somewhere.
Whatever the case, I had a good time.
You're thinking about it wrong. Voltage doesn't really matter that much since the voltage drop over the fuse is almost negligible. Fuses are not rated for a specific wattage... they're rated for an amperage.
A 10 A fuse will blow at 10A regardless of weather its in a 12V circuit or a 30V circuit.
Edit: You are right about the power of circuits protected though. A 10A fuse protecting a 12V circuit will allow a load of 120W a 10A fuse on a 24V circuit will allow a load of 240W
If you have a 560W max that you want to blow the fuse at that wattage for a 24V circuit you'd want 560W/24V = 23.33A fuse (Prob use a 25 or safely) for a similar 12V circuit you'd want 560W/12V = 46A fuse (prob use a 50A fuse)
Also keep in mind a fuse won't limit the current supplied ... it will just blow if it goes over a certain current.
So are saying for fixed resistance load, voltage and current are proportional so the fuse would blow at 10 amps unchanged by voltage?
But for a given power rating voltage and current are inversely proportional, so for 24 volt motor you would want 1/2 the fuse rating for the same wattage 12 volt motor, as you say above.
