Hey there. Just joined this site and I am amazed at all of the useful info on here. I have a 72 FJ40 I just purchased not too long ago and I have been wanting to ask a few questions but I understand there is a search functionality for the page. I had one question that I didn't find anything on.
I'm sure you guys all have stock Land Cruiser engines but i'm going to ask anyway. My SBC 350 has a pretty bad oil leak that gets worse when the engine is running. On the front of the block on each side there are 2 identical holes that look like they would be used to mount something at sometime but were painted over when the previous owner painted the block except for the top left hole on the frontside of the block next to where the fuel pump is mounted. The threads look as if they had a bolt or something in there. Oil is spitting out of the hole while the engine is running and all over the exhaust.
It seems to me that if this hole is leaking then the others would too being they don't have anything bolted in them either. Should I just put a bolt in there enough to plug it or should I do something else...ex.check seals? I attached a pic of a block so you all can see what hole I am talking about. There was never a part installed using that hole there before the oil started leaking.
Thanks in advance.
Mark
Thanks in advance.
Mark
