- Thread starter
- #21
From what the PO said everything checked out fine other than the EGR problem.
Deal with it Bogus.
Deal with it Bogus.
Deal with it Bogus.
I wouldn't trust a PO as far as I could throw him.
Yeah but we know for a fact that this guy is pretty legit. I mean, my e-brake cable was held together with a bent nail, but it worked.
Right now just need to get it to pass smog and get the throttle to stop sticking. I'll armor it all the way around as soon as possible, maybe re-upholster the bench so the foam doesn't fall apart.
I see some alcans and a crawlbox or two in my future though... Possibly.
Actually he should have used an old fence staple. Push it through, and pinch the ends together... Harder than all but high tensile wire.Bent nail? sheesh, didn't this clown know bailing wire works better?
Also just make sure everything's clean in there. I had a sticking issue myself, and it just came down to the carb gunking up from lack of proper use. These things get neglected, and ignored in the back of some PO's shop (or worse yet: their yard) and a film of grease and partially-evaporatd gfuel gunk builds up. I soaked it down with carb cleaner, filled the bowl with Sea-Foam, and never once had the issue again.I have not read the thread completly but mine ued o stick all the damn time. Make sure the butterfly on the carb , where the cable hooks up that those tabs are open, not pinched shut and the other standard ajustments
my tie rod fell off a few houses down from me,( i would not have done this repair any where but the trail and if i am close to home) so i pulled out my lineman's(kliens) and the tie wire, stuffed the rod end back up over the ball tie wired the hell out of it and drove it the 1/2 mile to my house!
some thing is off with that truck!
oh i see it has a fiberglass top not a soft-topper!
The EGR on the truck worked properly when we checked it. Take the blockoff plates that I discovered from the po that I bought it from and you should be good to go. I replaced the o2 already. I cant believe the e-brake was held together with a nail. Never had a issue with it so never got under it to look at it. All the smog parts are there and the harness has not been hacked as far as I know. The tranny is a l-52hd built by marlin himself. The transfercase is a 4.7 from marlin. If you have any other questions let me know.
