Newbie.. question and hello
Manhattan, KS
Hello all, I'm new to the Cruiser world. I inherited my 94 LC from my parents within the last year cuz my chevy bit the dust. When it comes to vehicles I'm not the brightest, but anyway I've known about this for awhile (like 6 months... atleast) but thought I'd ask about it. No real mechanical problems but here's a pic. Just wondering if you guys could educate me a lil about what this is, and if it's a big deal or not.
thx
brady
Likely an upper pan arch leak. Every FZJ80 has it sooner or later. It's a pretty intense repair. Not a big deal if it doesn't bother you and it doesn't leak enough that you're constantly having to add oil. The warped plastic piece that is pictured is easily replaced in less than 1 minute and without tools if you want to make it look better but it will still leak. Might not hurt to clean it up periodically so that it doesn't make a complete (worse) mess under your truck.
Welcome to 'mud!!! There's a great LC club in the KC area. https://forum.ih8mud.com/ks-mo-tornado-alley-cruisers/
Looks like the upper pan arch is leaking. I just did mine 2 weekends ago, and what a pain to do. I was lucky enough to have a car lift(my local tire guy let me use it). Very time consuming and the engine has to be lifted a couple of inches to remove the upper pan.
If it doesnt annoy you, I wouldnt worry about it.
Ya, I really should clean it up.. kinda embarrassing...lol. I add oil quite a bit actually, a couple quarts or so between every oil change. I've been looking in the faq and the archives but could never really tell what this thing was, thanks
If your adding a couple of quarts every oil chaing, then I would think about fixing it.
Make sure its the pan arch seal, because it can also be the rear main seal. Clean up the whole area and drive it. Then check the see exactly were its leaking from to make sure.
Both are big jobs, but the pan arch seal is a little easier. From what ive read here, its more often the pan arch.
Good luck
How often is "every oil change"?
That equates to one quart per ~1,500 miles. Toyota considers anything less than one quart per 1,000 mile to be "normal". You are well within specification.
I'll keep an eye on it but since it doesn't seem to be hurting much I think i better just let it go since I'm on a college budget. thanks for everyones help, I've really enjoyed everything on this site, there's some awesome LC's on here
