- Thread starter
- #41
1. May I see pic's the exhaust manifold ( 3 in one) without the heat cover? Nice tig weld, you do it yourself or somebody else did it for you?
2. I know level 10 back then- 12 yrs ago, the cost and the time frame- how long does it takes for them to rebuilt the tranny? cost?
3. I see you are in east coast, will these 1FZ-T pass the inspection, smog check?
4. Last one, just lil suggestion.I know its not that easy, but hey if you do have plenty time and know hot to cut the pipe, piece by piece and tig weld it- next step should build the 1FZ-TT, sorry the pic aren't mine.It's JDM spec, you'll be the first person in the U.S to own it, but also hope the level 10 (bullet proof tranny) will hold it.
Good luck![]()
Thanks
level 10 is very quick these days and if you want every possible upgrade the "bullet proof tranny" will run u about 5,700.00
yes it will pass our emission testing when the high flow cat is in place ,i have a mill adapter for the rear O2 sensor when the cat is removed.
I will be using either 2 HKS T 51R BB with v band in and out exhaust housings or 1 large platform turbocharger 90mm-106mm not sure yet.
, hahahahahaaaa, 4.5 Lt - good engine, congratulation for you killer machine
