Newb pleads for quick R diff lock advice
The High Country, NC
Got my truck and love it. Yes, truly an addiction.Searched high and low and can't find the post I had found previously.
Trying to troubleshoot rear locker - front took a couple of days to engage/exercise and now engages within 5-10 secs; however, the rear is being stubborn.
I have CDL/ABS lights and hear the click in passenger kick once diff lock switch is engaged for the rear but don't hear the actuator lock it.
Took a paper clip to the sensor harness and diff lock lights up on dash. Is it more likely to be the sensor or the diff lock has not seen enough slippage to fully engage and needs more exercise? (have tried figure 8s for a couple days now and still no engagement)
Sorry for whipping a dead horse but I really appreciate the help. JP
Describe the lights you are getting on the dash. Which ones come on when you turn the knob, are they solid or blinking, are you in low range (or have a CDL button engaged), etc.
How do you know the locker isn't engaged- are you relying on the lights, or tire scrub in tight corners?
CDL and ABS lights come one. Front diff lock light comes one, rear flashes. (When I insert a paperclip light goes solid)
Feel scrub from front for sure - dont feel rear.
I just now jacked up one side of the rear, engaged switch, and turned the tire and nada. (I think that was what I had read somewhere to try?)
Not sure where to go from here. Many thanks again for the input. JP
My bet would be a frozen actuator.
Yes, jacking up one tire on the rear is a good test. If that fails ( I assume the ignition was on and the center diff light was solid) then the actuator isn't working. Next you need to determine if the motor is turning or not. Best way would be to have someone under the truck listening when you turn the knob- again with the ignition on and the CDL light solid. Note that you may have to move the truck to get the center diff to lock, and you shouldn't do that with your friend lying under the tire. :D Preferably get the CDL light on solid and then shut down the motor, turn the ignition back on, and perform the test. If the motor is running, the spring might be broken or the locking mechanism might be stuck- at that point you'll probably be opening it up. If the motor's not running you should check for power, if it's there you'll probably be opening it up. (Sound familiar?)
Is the actuator for the rear like the center one? Same method like when my center lock was frozen just needed to engage and disengage a billion times?
Or do you remove it to RR?
I was hoping for a simple fix:crybaby:
Good news is that with such the excellent resource that this forum is and getting the RM and EWD off TIS today I should be in good shape to tackle it tomorrow:D
When the RM mentions adhesive and sealant for the actuator, what do I need to buy?
Thanks. JP
Yes, sometimes exercise will get them unstuck. If the motor is working I'd switch it on and off a bunch of times. If you want to go crazy, give the motor some time to rest between sets. :D If you overheat it you won't be happy.
If the motor's not running no amount of exercise is gonna help.
Spike - Thanks for the input - I"ll see if I can get my wife to listen under the under the truck:D
Retrofive - I think it hasnt been engaged that much, center enages, front does too, I am just moving switch to RR now. (I think I understood your question)
Thanks guys! Guess I'll plan on pulling the actuator tomorrow.
I say go straight to the motor with a 9 volt battery to test it.
https://forum.ih8mud.com/80-series-tech/241132-locker-actuator-9-volt-test.html
My locker motor was fine but the position sensor that made the light stop blinking was not working properly. I took it out, sprayed some contact cleaner in it and let it sit over night.
If the motor is working you know you need to focus on the wiring and testing to see if the 12 volts are getting to the motor connector.
The 9volt method is exactly what we used on my center to finaly get working again. At the time we didn't know what was wrong.
