Newb new/reman. engine question???
Fayetteville, AR
Alright complete LC newb. I'm buying a 97 LC off my cousin in a week. The rig has 193k miles. It appears to be in great condition. In the last year it's had the following work done: differential and trans fluid changed, new oil pump, coolant replaced, new valve gasket, brake booster, pcv valve, and egr valve.
I do not know if the HG has ever been replaced. That is a concern for me. I always like to consider worse case. I've already got estimates on HG replacement at $1500-$2000. And that's not including all the "go ahead and replace while you're in there" parts. I can get a remanufactured motor for around $3k but that's not including labor.
Which road is better if/when the HG decides to go, HG replacement with replacing of other parts as needed or replacing motor with a reman. motor?
How much labor is involved in just swapping out the engine vs. opening it up for HG?
If it runs well and doesn't use coolant, why worry about it? Or is it the "if it ain't broke, keep fixin it till it is" thing? Some here would have you believe they are frail, but in reality they are pretty damn well built, solid rigs, capable of taking significant abuse.
That gasket can last a very long time. When it goes, it doesn't necessarily grenade the engine. Personally, I'd advise monitoring some common indicators such as engine temps and coolant levels. If it works well and runs fine, I'd keep running it.
Oh I'm definitely going to drive it until something actually happens. I just wanted to know the best option: dropping $3k+ on HG and other maintenence vs. Just buying a reman. engine for $3k plus labor? I didn't know what labor was swapping engines vs. opening one up for HG. I plan on owning this LC for a long time.
Curious as to why the "Oil Pump" was replaced? The gasket maybe (they leak), but the oil pump itself...is an almost unheard of failure item.
I would never choose to use a re-manufactured motor for $3K. At that price you are going to get cheap components, not a full rebuild. Do a search on this website and you will see a properly rebuilt motor is going to be twice that amount. If the head gasket fails, the bottom end of the motor is still good to go in an extremely high percentage of cases.
I'm not sure why it was replaced. I need to ask. I just asked him what work had been done within past year.
