New
Hey all... Im new to Ih8mud... hope everyone is doing great...
i bought a 96 LC w/ 153k three months ago... its been running great until three weeks ago when i tried to start it, but it failed to start.
so i towed it to a shop they said it was the fuel pump! so i had them replace it. three weeks later, i tried to start it, but it just wont start... battery is good, it just wont start. so i towed it again to the same guy, he said it was the fuel pump relay but he told me it was fine to drive home ( he didnt replace it )
yesterday i tried to start it and it wont start at all. so i got a donner FP relay and it still wont start...
anyone have any ideas of things i should try?
thanks
Welcome to MUD, Need a little more info. When you turn the key do the gauges, lights, etc. come on? Does it make any attempt to turn the engine over or make a clicking noise? Could be several things, but knowing that info will help narrow the problem down.
First...Welcome!
Take a look at the FAQ section...it will help a good deal and remember Search is your friend.
Do you have a CEL (check engine light)?
Have you check all of the fuses?
Any other symptoms?
Thanks for the quick reply kenny... the dash lights come on. everything seems normal.
id doesnt ettempt to start. it seems like there is no gas ( but there is ) or fuel is not reaching the engine?
the engine turns but doesnt start. it just keeps turning... all the lights and guages work fine...
thanks
"Charlie don't surf"..... nice pic kenny
x2 what are the symptoms and did he change the filter while he was there??? Hmmm sounds fishy the relay wasn't checked before the fuel pump
It's not the battery. It's not the fuel pump. It's not the fuel pump relay.
Need more info, but did your mechanic rule out the starter? Some people change the starter contacts (very cheap, do a search).
Sounds like the starter contact points are worn out.
Do a search on the Netural Safety Switch. Sometimes the wiring or connector goes bad and makes the ECU think the vehicle is in gear when it is not and will not allow it to start. I remember reading that there are certian lights that will or will not come on in the instrument cluster if there is problem.
thanks for the quick replies and tips guys...
yes, its not the starter... the engine turns and everything it just doesnt start.
i think the mechanic changed the FP w/o checking the relay...
he didnt replace the filter, plugs, wires... how can i make sure it's indeed the fuel?
thanks
Checked the EFI fuse?
You're saying it will CRANK but not START?
If it cranks on command, starter, battery is fine. If it sounds like it's trying to start but just not getting enough fuel, or inconsistent firing, the plugs or wires might be bad but not likely.
Sounds like the Fuel Pump is not working (pump, relay) or the ECU is not functioning --> EFI fuse.
If the EFI fuse is blown, one place to check is the wiring to the O2 sensor that runs along the passenger side frame rail underneath the truck, sometimes it comes loose and rubs on the front propeller shaft and wears through blowing the fuse. Random and hard to find.
g'luck, Dan.
...oh, yeah, welcome to 'Mud.
Did you fix your problem?
Just realized that you never mentioned if you are using Toyota OEM replacement parts. Most of us here have a fettish on using OEM replacement parts unless the non-OEM replacement part has been IH8MUD certified.
maybe the same problem I had? take the time to pull the 2nd row seats and look at the fuel pump hanger and it's wires/plug, fairly easy and you'll find some change too.
https://forum.ih8mud.com/80-series-...es-faq-item-recommend-keeping-copy-truck.html
^link to the CNS trouble shoot page- like it says, print a copy and take to your mech, or better, do yourself.
welcome:flipoff2:, HTH
just looked back and noticed you do not have the year of your rig; I do not know if these parts/tips are the same for the 91-2 with the 3FE, bigger brains will be posting soon enough though.
no... it got late so i couldn't do more :wrench:...
i will do some more searching today and hopefully we find the prob. im sure it has something to do with the fuel...
two nights ago, i kinda wiggled the FP relay and the LC started... but then it wouldnt start the next day. i replaced the relay- and still no start. we'll see.
meanwhile, i got you guys some pics of my mighty LC on cardomain...
let me know what ya'll think
http://www.cardomain.com/ride/3818642/1
'96 ought to be the same as my '93 in the tank department, but like I said above- bigger brains are sure to chime in here soon. :cheers:
If you can get a little fuel and pour it into the intake manifold (just a cap full, not a CUP full) and then crank the engine. If it fires (it may even run a few seconds and then stop) either way if it shows signs of life you can pretty much rule out the ignition, starter motor, wrong oil, and even the cosmic flange torx converter along with the fluffer valve and giggling pin! Now go back to the fuel system.
regards
Dave
thanks tblume for the welcome...
Dave: what about started fluid? i sprayed some in the intake, then attempted to start- it started for a few seconds then died...
:lol: Dave's saying that you can eliminate no spark from the trouble shooting- along with a handful of non-sequitur 'problems'
the starting fluid gives enough flammable juices to roll the engine through a handful of stumbling rolls if you have air/spark/compression...
sounds like you might be having a no fuel pressure issue; looked at the trouble shooting schematic yet? there are a couple ways to tell if you are getting fuel pressure to the injectors; can't remember off hand but I think you should be able to hear the fuel pressure build at the injectors if you have a helper turn the key while you listen under the hood?
GREAT!! Now you have confirmed that you need to get fuel into the car to get it going. Now you need to get someone to crank the engine while you listen to the fuel pump, I have only diesel experience with LC's here in Spain and IIRC your fuel pump is in the fuel tank? If you cannot hear the pump whining then you could try lifting the IIRC the second row seating and remove a panel in the floor and try connecting a 12v direct to the tank pump, also at the same time check there is earth to it.
WARNING!! Make sure that all the car doors are open and that there is no smell of gasoline in the area before you try this.
If the pump runs leave it running and crank the engine, it it starts you have now discounted the pump, injectors, fuel pressure regulator, blockages, and of course that you have gasoline in the tank and not diesel ect. Now need to check fuses and along the wires for any damage and of course the relay. If it does not and you are sure you are checking it correctly then pull the pump and go from there. Also check to see if you have an inertia switch (this prevents the fuel pump from running in the event of an accident) these have been known to 'trip' by the simple action of slamming a door to hard (Jaguar) or banging the spare wheel into the boot (Ford) but I am unsure if you (a) have one and (b) where it is situated. Some cars rely on a signal to the fuel pump relay to keep the engine running but as you guys pretty much have auto in eveything it is possible you have both!
The ignition signal to the relay is often supplemented to get the engine running by the ignition switch, the fact you have run the engine we can discount that now. I would be looking at the pump and or relay and or fuse/wiring.
BTW, add a heading to this topic for example 'NON STARTER' as it tends to get lost and makes it harder to find when other people use the search facility later on.
Other mudders please jump in and help me as gasoline LC's are like hens teeth here!!
regards
Dave
Thanks to everyone- for the nice input.
well... tblume was right... the fuel pump essembly was shot. it kept burning the relay until we found that the plug was bad... so now i need to find a FP assembly...
