new winch
wisconsin
check out my new toy can't hardly wait to try it
very nice!! here's hoping you never need to use it!!!! Like that will happen...
Personally the much reduced surface area of the spacers and the resultant higher stress on both the winch and bumper mounting surfaces would worry me.
Utilizing spacers that would present a similar surface area to that of the winch mounted directly to a winch plate similar to what the bottom picture represents would leave me much more comfortable when using the winch.
attachment.php
I have the exact same set up with same winch (xd9000i) with washers as spacers in my ARB. I have never had any issues and done some heavy winching.
Is the bumper you have the deluxe bar or the commercial bar? I have the xd9000i and I am trying to sell and get an M8000 since I have heard the i-series wont fit the 80 series cruisers. What exactly are the spacers for? It seems the spacers will push the winch closer to the grill. Not having a bumper in front of me I'm having trouble visualizing. I have a 96 LX450.
Thanks
looks great!! now just make sure it doesnt need a drain hole in the housing .
i assume i have the same standard bumper most of us have as for the spacers they put the winch further from the bumper to clear the motor on the winch since the bumper has a taper and the 9000i
motor is bigger around than a m8000 and theres plenty of room under the grill and i did check the drain hole it seems to be open but thanks for the reminder jfz80
Hey guys, I started a mock up tonight and to get winch clearance in the bumper I needed two 7/16" plates stacked for 7/8 of an inch total spacer. This seems like more than what I am seeing in both of your set up pictures. Does this seem right? I was also wondering my xd9000i is an older model and measures 21 inches across. The motor sticks out 6.25 inches from the side of the winch. Are these measurements close to what you guys have? Thanks
thr spacer i used are 1" tall that is just enough to clear the motor and cooling fins . as far as the measurements go i compared mine with the m8000 winch that i had if you want exact measurements to Warn Winch - Truck, SUV & ATV Winching Systems & Accessories they will have all the measurements that you need or want
I know this is a couple months old but for anyone who has mounted a 9000i into an ARB, did you buy spacers from ARB or WARN or did you make/procure your own. Also, can you provide a picture from a little farther out. Thanks.
I used a 7/8" total spacer. I bought some 3/8" and 1/4" 2" wide bar stock. Using 2 of the 1/4" and one 3/8" pieces added up to the right thickness. These spacers give me just over a 1/8 inch clearance at the bumper/motor closest point. I chose those bar thicknesses so I could cut it fairly easily with my grinder and cutoff wheel.
I took some pics of my install and realized they were similar to what was already posted. Specifically what are you looking for as far as more pictures?
