New "whine" from engine after belt replace
Good evening Board-
As a new owner of an old truck (97) 40th I am getting PM done. Fluids, belts, tires, etc. I just changed the belts-thanks for all of the guidance on the Board, made it quite easy. Anyway, changed the 3 belts and now I have a whine. Stays pretty constant with rpm and I am wondering if tightening/loosening the pulleys etc .might have exacerbated a bad bearing. I have searched the Forums but am unable to find this exact event. No whine before belt change.
Any thoughts?
KCD
think I found it, unfortunately
A post from a few years ago stated that if you used Gates Belts, you would get the "whine" as they are not solid V belts. Can anyone vouch for this and does it go away? I thought these were decent belts, something like 17 dollars each.
Oh well....live and learn LC's right?
Good evening Board-
Any thoughts?
KCD
If the belts are not Mitsubushi brand they are more likely to whine,
in my experience; also, if they are overtightened they will whine.
ie: they should NOT be level with the sides/lips of the pulley, they should be slightly above the lips of the pulley;
If they are pulled too far down into the pulley, they will whine.
One way to check to see if it is the belts; just get your garden
hose and spray some water on the belts while the engine is running;
(stand back, and not to the side!!).
If the whine goes away for a few seconds, and then comes back,
it is the belts. ie: the water will lubricate the belts for a few seconds,
then as the water is slung off, the whine comes back.
G
A post from a few years ago stated that if you used Gates Belts, you would get the "whine" as they are not solid V belts. Can anyone vouch for this...
Yup.
There are many more posts on this besides the one you found. IH8MUD collective wisdom says no cogged belts.
And, it probably won't go away, unfortunately. :frown:
Curtis
If you don't know; Mitsubushi belts are what you get from the dealer. They say Mitsubushi on them
and have the Toyota part numbers also. I think that year also comes with a matched set for the alternator; either way, the dealer will know.
g
Just changed all 3 of my belts yesterday with new OEM belts from Cdan. The engine is as quiet as can be now, definitely worth using Toyota parts.
Now that we're talking belts, I went to change mine a few days ago, and try as hard as I could, I could not get the new belts on the pulleys. They seemed to be about 2 centimeters too short. They were OEM belts.
Does anyone know the part number for the alternator/fan belt for a 1994 80? I think I may have the wrong ones....
Don't remember the part #s off hand but I had to bump the ignition to get the A.C. belt back on, initially thought I had the wrong size belt but it jumped right on the pulley when I bumped.
90916-02353-83 (alt) and 99332-10910-83 (A/C)
About 21 bucks for the whole lot.
D-
Those Gates belts are excellent belts. Really, they are as good or better than OEM. You can run them for years. They will be loud as h@ll the entire time. Your friends will be envious of your "turbo".
I have run the Gates belts before with no issues, except the whine. OEM is easier on your nerves though, so swap out next time you have a chance. They arn't hurting anything except your ears.
For what it's worth, Gates is an OEM vendor for some of Toyota's replacement belts in the US market.
They supply (my personal favorite) supercharger belt..........;)
D-
Hmmm. Any idea why, even with the alternator completely loose, that they wouldn't go on? I tried for like 2 and a half hours to get them on with no luck. :doh:
Agreed, green stripes are great belts, but a little noisy on the 80, probably due to the flat idler pulley. I have them on mine and it's not that bad.
I don't have your year, but:
Any idler pulleys/tensioners, etc., that you might have missed?
Check all the way around the path of the belts and look for every possible tensioning adjustment; there're likely more than you'd at first think.
Curtis
Are you sure that you have managed to loosen the alternator tensioner all the way towards the engine? It's accessed from the driver's wheel well. Maybe you just loosened the alternator bolt in the front of the engine and that does nothing. It takes a lot of wrenching to get the alternator fully 'compressed' to put a new belt.
Also make sure that you route the belt correctly. Many guys tend to route the belts the wrong way around the idler pulley. In this vehicle the back of the belt does not touch anything, which means that it should go AROUND all possible pulleys.
And yes, if you used cogged belts, they will whine. I've got cogged belts for a year and still whines. Cheap tuner's turbo:frown:
I bought a set of OEM belts. I loosened the alternator as much as it would go. I removed the idler pulley that's almost directly underneath it, that didn't seem to do much, I even went as far as removing the entire adjustment bolt so that way I knew the alternator was as loose as it could go.
Which then was a bitch to get back on. :mad:
Which is why I want a 55. Same problems, more space to work with. :cool:
You don't have to remove the pulley or any bolts; just make sure all the bolts holding the alternator are loose and push it all the way in/down.
One technique I have used is leaving the old belts on and pushing and pulling on them to provide the torque necessary to get the alternator rotated, seems to help. Did mine a couple of months
ago, no problems.
g
I replaced all my belts yesterday from aftermarket to OEM. Getting the belts off was a cinch but getting the OEM belts on was a challenge. The hardest part was tightening the lock nut back up after getting the belts over the pullys. I found that the OEM belts are "taller" than the aftermarket ones I had on there and the OEM belts ride directly over the lock nut on the alternator adjustment. The aftermarket belts sit lower into the pullys and there was room to get a socket on the lock nut.
IMO, well worth it. I had a slight noise before and now it runs very quiet.
On another note, removing the battery and battery box made this job simple but I did have a rough idle after disconnecting power to the ECU (vis a vis removal of the battery). It cleared up after about 10 miles. I found that the best adjustment was 1/2 inch deflection measured between the center of the alternator pully and the center of the waterpump pully. For the AC belt, 1/4 inch deflection between the center of the crank pully and AC idler pully. The lip of all betls ride just above the top of the pullys.
