So I've installed a new water system. Sort of simple...sort of not.
Simple in the fact that there are no pumps, no electrical valves and the tank is easily removable. Sort of not, in that I soldered a bunch of copper pipe to make up the system.
I started out with a 4 gallon ATV water tank. I chose this tank because it fit up and out of the way on a bracket that I made that bolts to the rear seat belt bolts. I then modified the tank to have a lower hose connection.
I've run this tank for a while now with just plastic tubing and gravity feed. It works great, except for when the tubing comes loose and dumps water all over the interior...hence the new copper pipe which is much more solid, leak proof and easier to dispense the water.
First pic: Gotta show the rig. Parked next to a locomotive at the railroad that a friend of mine owns and that I volunteer at in my spare time.
Second pic: Shows the overall system. Everything is rock solid secure. The tank holds 4 gallons of water that I generally only use for clean up and washing water. I usually drink bottled water on trips just to be safe. It doesn't look like it holds 4 gallons, but it does.
Not shown in this post, a removable attachment goes on the end of the the outlet that extends the water pipe out past the tailgate.
Third pic: Shows the system from a different angle. The tank is nice and low profile and doesn't get in the way at all, which is nice. There's no perceptual difference to how the rig handles when the tank is empty or full. I ran the copper line where I did, because the left side of the deck flips up for access to storage undernieth.
