Hi all
I have a 88 bj74 landcruiser
I have just installed a new turbo from mamba TD05H-18G-7cm
Suppose to give me 20 plus boost all day long
Problem is i cant get more than 8 psi boost
Adjusted pump and have lots of fuel...black smoke
Have checked intake and exaust and all is good. Did a compression test and 426 psi on all cylinders. Had injectors tested and all is good. Removed intake to inspect turbo inlet. No rubbing of turbine or excessive shaft play. Plugged outlet on turbo to illiminate intake leaks and still only 8 psi with different gauge.
Running out of ideas short of removing turbo and taking apart
Maybe missing something ?
Thanks for any help
Marco
Thanks for any help
Marco
