New trouble Code
Dayton, OH
Hey Guys,
Well I installed my new ScanGauge this morning. What a sweet tool!
I was checking the codes and was clearing them. I of course have the normal P0401. But the one I was expecting was P0201, which is Injector Circuit - Cyl 1. The only thing I can think of that would have set this one off was that I had things torn apart on the top end on Sunday. I was replacing the valve cover gasket, the spark plug grommets, the throttle body gasket, and installed new plugs. I also cleaned the throttle body and did a little cleaning work in the EGR system, nothing really extreme. Everything went back together just fine and it fired right up, running smoother than before.
Well I cleared the codes this morning and when I got to work, the CEL was back on. I check the codes again and this time it was still my friend P0401. I am going to continue to monitor. But for all intents and purposes the truck is running great.
If anyone has any thoughts on the P0201 code, I would appreciate and insight.
Thanks
Pete
Oh and the rig in question is a 97 with 163K
Would that code have come because of the work I did on the engine over the weekend. I had several sensors unplugged and was jostling things around. Like I said in the previous post the truck ran fine after everything was put back together and it continues to run very good.
I anyone has any thoughts I would appreciate it.
On an aside, I came across this link, found it interesting: http://www.cleanmpg.com/forums/showthread.php?t=3432
