New to MUD
jynx
Turd Herder
Eagleville, TN
Well my wife and I just had our first baby girl and I needed something that I could put a car seat in since my 90 pickup doesn't seat three. I have become a die-hard Toyota man over the years so my first choice was for an FJ80. I was looking for an FZJ with lockers, but I fell onto this FJ80 and the deal was to good to pass up.
It is actually Kirkendol's 80 that he sold on here a few months ago.
Quick specs:
1991 FJ80 3FE Auto
ARB Bull Bar with PIAA's
OME Lift with 5 - 35" MT's on black steel
Full Garvin Rack with shovel, ax, hi-lift & spare tire mounts
Here are a few pics of her in my yard.
So far I have removed the rear tail-light guards and taken stock and here is what I have so far.
1. Have to re-wire the O2 sensors. I mean no disrespect to anyone, but anyone who does to a rig what has been done to the wiring on this rig should not ever be allowed to call themselves a mechanic. Evidently in the past one of the O2 sensors went out and instead of spending the $$ to just buy a new one and fix it, this so called "mechanic" cut the factory plug off and used what looks like a cut up lamp cord to go under the frame, over the pipes and splice into the working sensor. He at least left the plug... with about a 1/4 inch of wire on it :mad: So now I have two new Denso sensors on the way so I can fix it right so I can go get emissions run on it. I really want to figure out how to reconnect the plug, but I may have to just match wires and solder everything together, or go to the parts store and pick up a 4-pin and splice it in. Thoughts? I will post pics of this atrocity later.
2. The windshield has been replaced but not correctly. I am going go ahead and use firetruck41's fix to seal it up for now and also check around to price a new one installed properly, just to have so I can do that when the time comes.
3. Because of #2, once the windshield is sealed, I will be pulling the carpet up front at least and removing the factory insulation that has been soaking up water for some time and replace it as needed. Clean the carpets and try to get her water tight.
4. Have to get a grommet for the AC drain thru the firewall because the factory one has been removed to pull the wiring for the PIAA lights thru and it is also leaking in there, also.
5. I have cleaned the sunroof drains and will be replacing the little covers on the front of the sunroof since the existing ones appear to be warped.
6. Once I have her dried up, then I will be looking into some exhaust work. I checked out the system and it looks to be in good shape except the crossover pipe appears to be contacting the rear output flange on the t-case occasionally, and the muffler has a small hole in it, so I may have the crossover and muffler replaced, basically a cat-back. Any tips are welcomed.
7. The original sale indicated that the front axle was rebuilt a few years ago, but I am going to be doing it again since the pinion seal is leaking and it is leaking something more like grease instead of diff fluid (outer seals I think). If I am reading things correctly, the front end can be serviced using a standard 8" front axle kit, like the ones Marlin sells, correct? Definitely marlin HD seals, but would it be a good time to upgrade the tie-rod and draglink too. Mainly a DD with occasional weekend wheel.
Somewhere in the midst of all this I am looking for a semi-float 9.5" and a Hi-pinion 8" that I can buy and have a set of 4.88s installed into (35's + 4.11's = no overdrive :frown:) so that I can just swap the diffs and not have to leave her up on stands for an extended period. If I can come up with the $$ I am going to have an ARB installed in the rear also, with a front to come eventually. Will be checking classifieds, but if anyone sees some please pass it on.
That is my short list, and from what I have read, being a cruiser owner may take over my life, but it's ok, my wife only fuels the fire and nothing short of the best beast on the road will do for my new Baby Girl.
Proudly joining the ranks of MUD.
Jynx
where is the fuel filter supposed to be?
Thanks for the warm welcomes ********** :D
I have learned a lot already and have so much more to read. Search has been a good friend to me the last week or so. I do have a question that I haven't been able to look for yet, and if it is there I will find it, but where is the fuel filter supposed to attach to? Frame, engine block, ??
I say "supposed to" because mine is currently hanging under the engine and I know that is not correct. Every toyota I own has the filter securely attached to something. Figure I would replace it while I was tuning it up and get it secured so the fuel lines aren't under any undue stress. I just got my FSM, ebay is my friend, in the mail today and I can't seem to find a good image of the filter location.
Thanks again,
Jynx
Your fuel filter is mounted on the inner right frame rail, below the distributor.
Nice truck. Check my website for tasty 3FE tidbits.
JH Home
Thanks a ton. I kinda figured it was somewhere in that area. Now I just need to do a little more looking and see it I can find the bracket and bolts or if that is gone too.
Your site is definitely a wealth of info and I will bookmark it and may even print off some of your part number info, if that is ok.
I am particularly stoked about the connectors links since I am trying to figure out how to put the passenger side O2 sensor plug (rear bank, IIRC) back onto the harness. I still have the plug, but it only has about 1/4" of wire left on it and I was hoping that I could pull the short wires out and put new connectors in and re-pack them. Do you have any experience in that department?
Also the cd's that you offer, I have a hard copy of the service manual and wiring book and was wondering whether you might sell just the connector, and other remaining tidbits?
Thanks again,
Jynx
