New Tires!
Chicago and CA
I am due for tires, as my second set of MTX's are nearing their demise.
What is the largest size tire I can mount without a lift or any rubbing? I want something that is big so that if I ever lift it in the future, I wont have to replace the tires because they are too small.
would something like 285/75/16 or 295/80/16 work?
what is a good snow tire?
A search will offer you up a LOT of threads on this issue as will the tire section in the FAQs (sticky at the top of the 80's forum)
However, to get you started I know the 285/75/16s will fit as they are on my LX right now. Do they rub? Don't know but I believe from what I've read in the past rub would be minimal and at full articulation.
As for a good snow tire...Lot's of opinions on that. Best is a dedicated snow tire IMO if you can justify two sets of tires.
If not then you need to compromise and determine what you will mostly use the tire for. Street, off road, combination?
For mostly street you may want to look at the Bridgestone Dueller AT Revo's that some have had good luck with (IdahoDoug for one I think). Some like BFG ATs.
Personally, I have the Toyo MTs with siped centers and they absolutely rocked this winter. We had some pretty good snow storms this year (2+ feet at one time in town) and the LX went through the white stuff like a snow mobile. The one negative is they are a fairly heavy tire but they sure look good :D
you have the exact look i am going for. the mtx's are really not holding up well in the snow, and was really impairing the trucks performance.
i still have time, but am just looking for some advice from this forum.
A lot depends on the temperature...If you search for posts or comments by IdahoDoug you'll find one where he wasn't all that impressed with the AT Revos at first. Then it got colder and the tires seemed to stick to the snow better. I had Revos on my non-Toyota DD and thought they were ok in the snow but nothing compared to the Yokohama snow tires I had.
Compared to both of these though I think the Toyo MTs are in a different league. They are siped in the center though which I believe has a lot to do with their performance. I am also amazed at how relatively quiet they are for a MT. They seem louder as slow speeds as a matter of fact. And they are definitely quieter than the snow tires.
The problem with the Toyos is the cost and the weight, especially if the majority of your driving will be on the street. I like the look as well and wonder what it will look like when the OME 2.5" lift is installed...
Good luck!
255/85 MTs stock height pic. Sorry -cant find my side shot. this shot is with 1.25" spacers to yield roughy the same width as 305s which is the largest that would work without rubbing at stock height. Tall skinnies dont look too bad with spacers-and arent too heavy and leave the steering fairly responsive. They are about 33.4" overall diameter which is a bit taller than most 285/s which avg around 32.7ish. The best part about them is that they somehow added about 5.3mpg city and 7hwy.........
In our Prescott area I see a lot of 80s with no mods except for a set of 315"s mounted. This is similar to mounting 31's on an older 4Runner or Montero. It is the largest that you can do without any other mods. It is the mod that a soccor mom will allow Dad to do to "her" truck.
Some will disagree as the 315 will rub on the rear fender well if you do not add to the rear bump stops a bit. I have seen plenty of trucks with the rear inner fender wells polished with no ill effects.
I've seen several stock 80's all twisted up with 315's on them. It works OK.
