- Thread starter
- #41
I just got a tracking number today, hopefully these will balance.
for you... maybe you could bend a light bar for me? I am thinking just a hoop welded to some angle iron feet that I will screw on top of the ramp. I should have everything done by then but the light bar shouldn't be any big deal. Do you have an example in mind?
bhmmapping said:update - finally got four of the tires balanced enough to actually drink a cup of coffee on the way to work. Considering the condition of the roads in downtown Bhm I am actually pretty happy with my setup now. All total I have received 8 tires now and 4 are good. I may be able to get my spare balanced but I will have to break it back down and spin in to the rim. It took close to 8 oz of beads which about twice what the balanced tires took.
I thought I had found the source of the leak, but after cleaning the area and taking a test drive coolant is still dripping but the source isn't where I thought. No codes and runs fine, I'm thinking about just building a catch pan and selling the stuff since her car appears to be producing coolant.bhmmapping said:Oh man, glad the Honda is working out for you. I hope the transmission is still working? uh oh on the leaking coolant. I don't think it is manufacturing it, you probably will want to keep an eye on the oil level too. Was she in Bham yesterday? A girl in a Rodeo that looked like her with a 64 tag pulled out in front of me in Homewood yesterday.
Cruiser is fine as a DD. I've still got some vibes but I think I have narrowed it down to the rear driveshaft. I never reset the pinion angle after the trans swap and lift. Now that it is a DD I have to actually worry about fixing it.
I do need to check her oil... She wast in bham and she has Illinois tags.
Tranny is still working.
posted with my thumbs.
good to hear on the tranny - definitely check the oil since it could be mixing with the coolant for some reason. Bad oil cooler or headgasket.
Did I ask you if the timing belt has ever been done on the honda?
