New Thread
... now here's what we got: :meh:
Order remaining peices with a 10-week delivery. Means shipped 10 September. Again, common carrier freight across the country means delivered 17 September.
Done 01 October. :cheers:
When's the Redneck Gig at Superlift?? Ain't that in October?
Axles still not delivered. Obviously not done tomorrow on 01 October. Won't make it to the Redneck Gig. :frown:
:flamingo:
More pics of Lady Sonja please!
And how 'bout a pic of the truck!?! :cheers:
Line-X shop finally got 'round to sprayin' 'er lower panels. :clap:
Thanks for the pic Lance. :cool:
:flamingo:
So it was 2 months to get the Atlas ... and then 3 months after that we now got the axles. It's GAME ON now!! :bounce2::cheers::bounce2:
The Front:
Complete Custom Dynatrac Pro Rock 60 High-Pinion 8x6.5" Front Axle Assembly w/ARB Air Locker - 02 F250, Auto, 7.3D
Custom Machined Dynatrac Pro Rock 60 High Ground Clearance, High Pinion (Reverse-cut) Heavy Duty Nodular Iron Housing
Heavy Duty 3.125" Diameter, .50" Wall DOM Axle Tubes
Matched Housing Geometry, Pinion Angle, and Wheel Alignment for Vehicle's Suspension
Axle Width - Use Factory 2002 Ford Width min. 69.75"
ARB Air Locker Differential, D60, 35 Spline, Installed, w/ARB Kit
Choice of D60 Ring and Pinion, 4.56 Reverse-cut
Yoke, D60/70, 1410 U-joint, Strap, 29 spline, with strap kit
Upgrade to 35 Spline Competition 4340 Chromoly Inner/Outer Axle Shafts w/CTM U-Joints
Warn Premium 35 Spline Locking Hub Assemblies
Dynatrac Pro Series 60 Heavy Duty 8x6.5" Wheel End Package (Includes Dynatrac's HD Forged Steel End Forgings, Nodular Iron Knuckles, Chromoly Spindles, Nodular Iron Wheel Hubs, Serviceable Timken Bearings, & Spicer Ball Joints)
Dynatrac Stub Hub Kit - Optional Upgrade
Heavy Duty F-350 Dual Piston Disc Brake Assemblies - (17" Wheel required, Upgrade to Extreme Duty 14.5" Vented Rotor Disc Brake Assemblies)
Cross Over Steering Package (Includes Tie Rod, Drag Link and RH Steering Arm with Hardware)
Drag Link will ship later after customer supplies length
Spring pads located for proper suspension geometry 6.0" Spring over suspension - ICON
Dynatrac Pro Rock 60 Nodular Iron Powder Coated Diff Cover - Upgrade
ABS Retro - No ABS
Gear Oil, Installed
Axle is Detailed and Primer Painted
The Rear:
Complete Custom Dynatrac Pro Rock 80 Full-Float 8x6.5" Rear Axle Assembly w/ARB Air Locker
Custom Machined Dynatrac Pro Rock 80 High Ground Clearance Standard-Cut Heavy Duty Nodular Iron Housing
Heavy Duty 4.0" Diameter Lightweight, High-Rigidity DOM Axle Tubes
Matched Housing Geometry and Pinion Angle for vehicles Suspension
Dynatrac Pro 80 Dual Sump/High Volume (DSHV) High Pinion Angle Oil Modification
Axle Width - 69.0 - Match with front
ARB Air Locker Differential, D80, 35 Spline, Installed, w/ARB Kit
D80 Ring and Pinion, 4.63 Standard-Cut, Installed
Input Yoke, 1410 w/Strap Kit
Dynatrac Heavy Duty Pro Rock 80 Full-Float 35 Spline 8x6.5" Wheel End Package (Includes Dynatrac Heat-Treated Chromoly Spindles, Nodular Iron Wheel Hubs, Serviceable Timken Bearings, wHD Dual Piston Disc Brake Assemblies w/p-brake)
Dynatrac Severe Duty 10K Pkg. ( Includes upgraded wheel hubs, HT spindles and bearings)
Dynatrac 35 Spline, 1.5" Diameter USA-Grade 4340 Chromoly Full-Float Axle Shaft Assemblies
Spring Pads / Shock Mounts - Loose
Dynatrac Pro Rock 80 Nodular Iron Powder Coated Differential Cover, Installed
Gear Oil, Installed
ABS Retro - No ABS
So I'm thinkin' these'll do the job right nice. :grinpimp:
:flamingo:
Well Darn sir, I am impressed with all the specs! :eek:
....too bad it still a Stupid Duty!
a good ol' dodge would have done the job ...
:grinpimp:
project it's looking nice!
Vince is givin' 'er hell now By Gawd!
Here's some pics of the big-ass rear bumper. :cheers:
Notice how the taillights are damned near out of view. Aluminess said this would not be the case but I had 'em put the extra LED units in the bumper itself anyways ... BRILLIANT! :idea:
:flamingo:
Done told y'all it's showtime ... blink now and you're gonna miss somethin'!!:bounce::bounce2::bounce:
My wheels done got delivered today. :clap:
Went with some 17" Spyderlocks. Highest weight ratin' we could find and just overall bad ass. Notice how it takes a 17" rim to clear the massive brakes we got on the axles. :cool:
Don't fret none 'bout the shiny finish ... they're headin' to the powder coatin' fella and will come back black. :grinpimp:
:flamingo:
Nice stuff Kowboy
How longs this gonna last.... ?
clutch
'Nother big day in the shop by our main man Vince. :cool:
Lookin' like the topic of the day was steerin' ... lil' hydro assist from AGR to be exact. :cheers:
:flamingo:
WOW :eek:
As usual, very impressive Sir! :bounce::bounce2:
You're right about the tail lights it's really hard to see 'em.... great :idea: on the bottom lights
