New Spindle Lube Question
Beaumont, Texas
Website
www.marklowimagery.com
I have the newer style spindles with the pin bearings instead of the bushing and wondered which grease to pack inside them before assembly? Should I use the Birf/Moly grease or the Lithium high speed wheel bearing grease? I figured the high speed lithium would be best but then thought it would just mix with the moly/birf grease so does it really matter. Which one to use, the Moly/Birf which is grey black or the wheel bearing lithium which is a red type?
Ok Another dumb question... I'll just pack it with the Moly since it will mix in there from the birf unit anyway, even though it is in a high speed service area. Probably better to not mix the two types in the birfs anyway.
Why not use the Amsoil Moly - it is rated for high speed stuff like wheel bearings but also accpetable for birfs although recent readings tell me that the moly percentage is possibly a little low. HTH :cheers:
Yep that is what I'll do. The Moly will end up in there anyway so it shouldn't matter.
Thanks
I used the Amsoil grease. I did use the wheel bearing grease (red) on the spindle bearing and just figured some of the moly (purple) would work its way in there eventually. You don't really need to worry about it contaminating the birf as the open end of the birf is on the other end. I wouldn't worry about having a little wheel bearing grease in the knuckle housing.
