New spindle lock nuts notchy??
Trying to use new spindle lock nuts and can only turn them with the hub socket and they feel notchy. The old nuts are probably the originals and turn easily by hand all the way up. I rechecked the spindle threads and I do see and feel very slight dings where the thread meet the key way for the washer. Any problem with forcing them on?
Mine felt the same way. Just ran them on with a socket nice and slow with no problems. Since then I have removed and reinstalled them with no issues.
D
I think that's it, they are just new and in spec, then add the little dings in the threads at the key way which explains the notchy feeling. I tried the other bare spindle (should've done that first) and one of the new nuts went on a bit easier. Guess I could pull the hub off and try to clean up the threads??
Edit: I ran the new nut all the way up with a ratchet and backed it all the way out and saw a small amount of debris in the key way, took my handy lighted telescopic magnet pick-up thingy and voila, the particles were shavings from the nut. The spindle acted like a die (harder steel than the nut?) and now the nut goes on much easier. Next time I have it apart I might try to clean up those threads. Learn something at every turn.
