New Ring & Pin, break in Question.
O-side, CA
Website
www.thelandcruiser.com
Question:
1. Could excessive preload cause vibrations?
2. Dose it take time to break in a new ring and pinion?
I have done the search on diff vibrations, and have answered some of my questions, but felt the need for a personlized post.
Short Version:
I just had a new ring and pinion put into my 3rd rear end. Preload seeemed a bit tight, and stupid me slaped it in before checking it, because I paid a reputable shop to put it together becasue of time constrants. (see below for the things to make fun of me for).
At around 3500 rpm I get a vibration, and then around 3650 it goes away. Wrose in 3rd gear, but feels like it comes from the rearend. Also this vibration is apparent during high rpm decel.
Knowen Grimlems:
My transfer case will vibrate inbetween accel and decel at 50 plus. Always has done this, still dose. the new vibration comes only after I let someone else touch my rig.
Things to bash on me for:
1. Letting someone else touch my rig.
2. Paying someone else to touch my rig.
3. Not noticing that it looked like the bastards at the shop
used an hammer and flat head to tighten the carrier bearing caps.
4. Being sad because I let someone else touch my rig.
5,slaped it in before checking it
No.
It will cause premature bearing failure, depending on a number of factors, including, but not limited to: Lubrication, amount of preload +/-, quality of bearing, number of hours on the tight/loose bearings.
I would bet that your vibration issue is related to something other than your diff work, unless there is something else that has gone on that you have not shared with us.
Remove the rear drive shaft and operate the truck on just the front end, and see what happens with your noises.
Why do you have a vibration in your transfer case?
No.
Between test drive without this new vibration and it showing, up, I ran some air lines and only the 3rd member work has been done, I swear.
Yes, I will remove the drive shaft and test that tomorrow.
Trasfercase - ok that is a guess, maybe the pinions are out of phase, I have always had a vibration while going 50+ when there is power trasfer betweed Acceleration and Deceleration. But have been able to cruize at 80 smooth as butter.
so after I remove my rear drive driveshaft there will be one of two outcomes.
1. vibration is still there - means 3rd is fine.
2. vibration is gone -
a. pinion is breaking in?
b. now that 3rd is all tight, stress/vibrations are apparent in the weakest link (transfercase).
c. now that the 3rd member is tight, my phase problems are mmore apparent.
yeah, I know, need to check off as many of the above as possible before posting again.
Thanks for all the speedy input, I can give the wife some attention now, that I have a plan for tomrrow.:cheers:
ok, I took off the rear drive shaft and went for a spin.
I was just bairly able to feel the same vib, but -x90.
And again seemed to be coming from the rear. and not traveling through the drive line as before.
The guy at the shop said they had a hard time getting a good paddern but did get one in the end. The whole ring was covered with paste, I don't know how they knew which one was the most recent.
I will test it in the morning again. This morning is when it howled the most. So after it sits cold all night, it might be easier to pinpont.
Never did care for front wheel drive, just feels wrong.
Guess after I do my morning run, and If I still think its the rear end, I wll pull the cover, and put some gear paste on it, and take some pictures of the tooth contact.
Thanks again and good night
I would be equally worried about that transfer case as well. Especially with a 350. Sounds like it's crying for a rebuild or at least a new idler shaft and needle bearings. I waited too long to rebuild three different T-cases I've ran and lost teeth on the idler and high/low gears on all of them. Not good;)
Did the shop give you a explanation why the set up was a problem? what brand name gears are they? I had a Yukon set once and ring gear was out of round..
the hard part
eating some of my words.
Last nights test run was not accurate. I only tested for a block, in 3rd gear, but this was going up hill. Vibrates way less with a heavy foot. (Answer: Stomp on it all the time:). JK)
This morning I drove around for a good 15 mins with the rear driveshaft disconnected. The vibration is there, and at higher speeds now, it vibrates even worse.
I think I now need to focuse less on what someone else has worked on(3rd) and concentrate more on what I have not done. It is hard not to put blame on a component that a shop, who uses a hammer and flathead as a tool, worked on.
Strange for it to show up just after having the 3rd done.
OH well, I will make sure I have plenty of oil in the transfer case, and deal with it until those orions are in production.
Last heard (november) was the new date. (unfortunally my dog got diabites and I spent my 3k Transfer Case money on her. Need to work more. Oh, my dogs new name is TC)
Again thanks for the advice, it really helps to have people to talk about this to, besides myself.
"Go crazy, don't mind if I do."
Homer Simpsion, episode xxx
Item 7 to bash on me for: Makeing a good case against a component because of my feelings towards people who use a hammer and screwdriver as a tool, and draging muders along for the ride.
You would be surprised at the number of repair shops that can't set up a gear set... There are 2 in my area now... one brings 3rds to me to do... they go as far as to remove the whole axle assy.(Dana style)and bring it in because they don't want anyone to know they're subletting work out......Both are large major repair facilities.... Sorry about your dog...
It always seems to take longer and I don't like the results when I have someone do any work for me, that goes for my cruiser and computer work.
The Dog is actully doing great now. I have to give her vetsulin shots before I feed her, but her weight is now down and she has more energy. Amazing what 3k and modern vodo, can do for animals.
