New Radiator = Over heating
Vail, CO
Had the fan belts break on my wifes truck and it got hot and cracked the seem on the radiator. Replaced the radiator and now it always gets hot going up very small hills when the rpms hover over 3000. The truck returns to normal temp in less than a minute when going back down hill.
Replaced all fluids and put a new thermostat in. It never gets hot at low speeds, even when driving up steep hills at 12,000 ft.
Other than a blocked or faulty radiator, what could it be?
Thanks,
James
I'm going to start with the easiest possibility and that is trapped air. Especially since this happened AFTER the issue with the radiator.
One was already broken I suspect. Water pump was checked out and is ok.
And the other natural question - who's radiator did you put in there?
DougM
James, as others already pointed out it can be a few things:
1. Air in the system - Park the truck on a pretty steep slant, nose up and cap off, and let the air migrate up to the neck. Sometimes I slowly squeeze the upper and lower hoses to help the system burp.
2. Water pump - All that I've heard or read suggests that unless it is leaking, and as long as the thing spins smoothly, it is probably good so scratch that off the list unless it is leaking or unless it is rough when rotating.
3. Wrong radiator - unless it is OEM or something like a racing radiator it is possible that the radiator just isn't efficient enough - in most cases all the aftermarket radiators seem to work well enough though at least at first, they just leak a lot over time and require replacement much sooner than the OEM variants.
4. Something else screwed up when the thing overheated that one time - perhaps a small split in the HG or something such that at the higher RPM's gasses are getting into the coolant (hopefully not and probably not, but just one possibility).
Is your coolant level changing at all in the overflow?
Thanks,
James
How old is the fan clutch? Is the timing too far advanced?
