New Project, no go, help
How are you checking for spark? Holding the plug wire off a block ground or using a timing light on each plug wire?
This may seem far out, but recently had a similar problem with new rebuilt engine. I got spark through the wires when I pulled the wire from the spark plug and held the wire near block ground. Tracked down the problem to bad spark plugs, yes all the plugs were new, but bad. The electrode through the plugs was some how shorting out internally to ground. Changed out plugs and it started on the first crank.
IMHO if you used starting fluid and it didn’t fire, you do have a spark/timing problem. Pull a plug or two, connect the wires back onto the plug, hold the side of the plug securely to a block ground and crank the engine. You should see spark jump across the electrode, not from the plug body to ground, across the electrode gap.
Jerry D.
Have you adjusted the valves correctly yet? If it sucked on your thumb over the spark plug hole, the intake valves may not be opening at all, in which case they're probably all misadjusted. Have you actually watched the rocker arms push the valves down while cranking?
For an easy test, pull off the air cleaner (at least the top) and put the palm of your hand over the top of the carb while cranking. I suppose for liability's sake I should recommend that you use a piece of cardboard or something similar :doh:
Ok , heres the update, The points gap is good i adjusted all valves as per manual, purchased a compression gauge and tested. I had to test cold as i cant get her to fire.
cylinder # Dry Wet
1 70 70
2 60 60
3 60 60
4 60 60
5 60 60
6 70 70
I know these are very low but they are constant. ( trying to be positve) What would be some reasons for such low numbers??:confused:
I have an f engine with a 2f head that i may be able to use although i think the oil delivery system is different. As there was little difference in the wet and dry test i guess it look like stuffed valves. I think i might take off the head and get it revalved.
what do you guys think??
I think the old engine i have may have the f.5 head on it, the castig # is 60030 . It had a 2f valve cover on it but it was on an f engine. The pistons (it was covering) have four little scoops out of them. Anyone???
I have both heads off the engines now so i'll have to compare them. One of them is going to get rebuilt just not sure which one, i'm tempted to stick with the one that was on the engine i'm using, but if the other head will give me better compression.....
desisions , desisions.:idea:
Figuring out compression
Hello again,
Too bad you pulled your heads off already but hey it did give you a chance to deal with any head gasket leak.
Head gaskets can give you tan or milky colored oil or pressurize the radiator when compression leaks into the cooling system
for a head gasket you would expect to see one or two cylinders 20 percent lower or more than the others.
Since all your compressions are close I bet it's rings ---in that case put a couple squirts of oil in each cyl or about a soda pop cap full per cyl. You should see all the cylinders rise in compression about 10 percent or so and if they do that tells you your rings are worn.
If that is the case your not going to help yourself by trying to raise the compression with the heads.
One more thing to check is valve timing--check the timing marks between the cam and crank. A jumped chain can cause the valve timing to be off and you actually have the valve open a little on the compression stroke.
also you can check the condition of the valve and seats by backing off the adjustment on both valves or rotating the engine until they are closed and putting compressed air into the cyl --- if you can hear it leaking into the intake manifold then the intake valve is bad, into the exhaust then the exhaust valve is bad. THis is not likely with all the cylinders being so equal though
I would expect over 100 psi for your compression however you are doing this on a cold engine also.
I'd check that timing chain for sure though It's not unusual for a high mileage chain to jump teeth although I'm not and F-eng expert but I imagine it holds true.
So long story short
leaking head gasket
worn rings
valve timing
worn valve/seats
Plus a little off for the cold engine check
all valid for the low compression but with only 10 psi difference most likely would be valve timing or piston rings
Good luck and please let us know the outcome
heys guys thanks for you help (i need all i can get). Sorry if i confused you, but it is a 2f im working with , but I do have an old f out the back i was thinking of using. I have decided to stick with the head i took off the 2f engine (safer). I did do the dry and wet test and there was no difference in compression. So i figured it must be the valves/valve seats that was the prob, which is why i took the head off. The head gasket was all good and the pistons and chambers also look good. Now you got me thinkin it is the timing cam and crank off line. I don't have the SST tool to get the pulley off to check. do you really think the cam and crank could have shifted poition?? I'll get the head and valves redone anyway now they are off.
Don't leave us hangin' Shorty Forty--let us know if you're up and running when you get the chance (and what it turned out to be):beer:Dave
G'day romegadave,
Well its turned out pretty sad really, i had the head crack tested and she was full of cracks:crybaby:. So I'm thinking the engine was cooked at some stage. This means i will have to find a new engine for her. I'm just playing it cool at the moment as a 2f will turn up soon , i can feel it.
