New Product Input - Adding a factory looking illuminated switched circuit kit
LandCruiserPhil
Peter Pan Syndrome
Supporting Vendor
Graham County, Arizona
In doing some electrical work on a 200 series I found the need for a quality low cost factory looking switch and circuit that could handle some amperage.
Pictured below is what I came up with to offer to the 200 guys if they see a need.
Cube Bosch style relay 30a rated with 5 wire pigtail
Add a fuse with 15amp fuse can be fused 5a - 30a
Factory looking illuminated switch. Fits in factory location. Switch has 2 sources of illumination one for the logo (normally dash light powered) and a bright indicator (normally used when switch is on.
Wiring diagram to show how to wire in your lights or ?? to our parts.
You can see pictured below I relabeled the 2 I installed. Sadly the camera see the switch as your eye. In person the color match is much better and my relabeled in not near as noticeable in the picture.
Price point is estimated to be $45 for what is pictured and O'course FREE SHIPPING :)
Thoughts?
Thoughts?
View attachment 1790303 View attachment 1790304 View attachment 1790305 View attachment 1790306
Hi phil ,
I Really like the OEM Look , Factory Type Fit and finish the JDM fog Lamp logo is there
My only input would be make the Illuminated ON rectangle box a LED bulb if possible & the Color whether Amber or green in
step with with what would be the rest of the switched ON interior illumination
i like the green electrical connector too , Very OEM JDM ......;)
matt
You'd still need to source the relay but there are tons of factory-looking switch options available from Air OnBoard:
SEQUOIA 2008-ON - Toyota Switches -Air On Board
The LEDs are a bit greener than the factory switches by default, but apparently they now have switches where the color is supposed to match:
SEQUOIA Replacement Switch LED light GREEN -Air On Board
Given all the crazy switches they offer, if they don't have precisely what you want, you might email them and ask if they would do something custom.
Thanks for sharing , Nice link
Can I assume the Sequoia switches fit the 200 correct?
Yep, the Sequoia and LC use the same 900-series switches. I've bought three for my rig - 920G, 9B04G, and 907G.
