new potential
LOL mrboatman--- one of your old posts was one of the things I looked at where you had the same observation.
Curious what makes you 69 didn't have a air pump? Is there a large used port on the air cleaner cover? Does the harmonic balancer have a two groove pulley? How about ports in the head for a injection rail. If yes then it may have had a air pump. If not then maybe the 3/69-9/69 didn't have one. Do not believe no one was doing a annual emissions texting when these were new and most were probably yanked out pretty quick. I know my 68 when it went thru emissions they tested tailpile emissions at idle and running. No inder the hood visual inspection. Also did a gas cap inspection. Only see that you had one not that it had a good seal. Some 71s and all 72s were a sealed system with fumes recovery. Those had a sealed fuel tank. Guessing that was a real big change in emissions.
I have a 3/69 and it does not, and never had, an air pump. F145 engine and no air injection ports. Also, no extra air cleaner port.
If they skimped on the rear floor would make me wonder what was used on the rear sill. Serious doubt the floor rusted out and not the rear sill. Having a continuous channel in the back that is in good shape is important to handling the weight of the hard top.
I'm just not feeling frame of restoration on this one. Something is not adding up here. Frame off to me represents a truck that was returned to its original splendor at some point. Im not seeing that here. If that is not the case, what else maybe has been exaggerated. Add the 12k price to the equation and Im scratching my head.
