New Pioneer Project
I'll try to get some box measurements after work. The data tags were posted here:
attachment.php
Yeah I saw those, sorry I guess I should have asked for the width. without the fenders. Guestimating, I would think that the fenders would be around a foot give or take so I am thinking, 6.5' x 4' ish? Maybe?
Dave,
If you are going to mount a water tank the cross bars and axle will make it difficult to do so under the box and directly above the axle. I mounted mine forward of the axle If you do the same along with the propane tanks, etc. on the tongue I don't think you will need to worry about it rotating backward. If you still decide on making the the stands why don't you make the mounts for the RTT a little wider and then run a smaller square tube along the inside of the original mount and drill holes to use with cotter pins. It would be a more streamlined system then something that pivots.
chris
That's a great idea, but the rack is already welded to the frame. I was thinking about a similar idea that would run the legs on the outside of the vertical posts with pins.
LOL! Sorry to disappoint. It's been hot as hell and I've been busy. I did finish my 4x4labs bumper. Anyway, I've been accumulating electrical components (130W solar panel, charge controller, on board charger, water pump, etc). I also got some rims and 33" tires. Just need some time and better weather (100 degree days here).
