Following.. any update?Any updates so far on heat buildup with the stock dustcaps? Did you orient the LEDs vertically? Or horizontally in the housing?
I installed and have used the LASfit plug n play August 2024. Significant improvement and no problems with stock wiring as they advertise.Following.. any update?
Yeah, I'm still running halogens for the low beams and high beams. Once I go to LASFIT LEDs for both high and low, will disconnecting the the connector to the resistor still allow the high beams to work when switched on?You still run the drl’s? That was about the 1st thing I got rid of. It’s a simple connector to disconnect.
That’s what i put in shortly after i got my LX back in 2021 and it hasn’t skipped a beat. I found that there’s LSAFIT factory retail store near me. Might have to stop by. They also sell LED turn signal bulbs as well. I had them in the taillight of my 5th gen 4runner and that thing was BRIGHTs hell.I still have halogen as well. I just disconnected the drl’s because, well… the comes come on when I say so, not the car.
The group seems to like the Lasfit, maybe I should give it a go.
Yes, high beams still work.Yeah, I'm still running halogens for the low beams and high beams. Once I go to LASFIT LEDs for both high and low, will disconnecting the the connector to the resistor still allow the high beams to work when switched on?
Thanks,
Gary
Is this an LX or LC?Installed the LASFIT LA Air Series for low beam and high beams. The high beams are crazy bright. The low beam is definite improvement over halogen (it's hard to capture the difference using the iPhone camera because of auto brightness). Low beam and high beam photos below. The fence is about 20 feet away. The DRL does not come on as expected but I did not have to unplug the resistor since there was no hyperflashing when in DRL mode. Install tip- Remove the windshield washer fluid funnel and batter from the driver's side for way easier access to the high beam bulb.
View attachment 4028073View attachment 4028074
2005 LX470. I polished the lens before the install also (using the Sylvannia Headlight Restoration kit).Is this an LX or LC?
