New issue need RTH.....
North GA
Water leaking from right rear side of rear engine firewall.....trying to track the leak......steam was pouring out but my temp gauge didn't go crazy. Rear heater core??
Driver or passenger side? If driver then I would suspect either phh or one of the heater hoses behind the engine. There's a hard line that runs behind that could have a bad coupling point as well
I'm attaching a pic from a bit of water dripping from passenger side. The hose looks like a condenser hose that is supposed to drip water.
On the other side we've been inspecting the PHH....that was my first thought because the steam was coming from that area. And the PHH looks bad but not broken etc. looks a bit damp maybe.
Could be a clogged or broken ac evap line. Is you PS floor wet at all?
Touch the water. Is it hot or cold? 5/8 inch heater hose and two clamps will allow you to bypass the entire rear heater assembly till you can replace the need parts.
