New Guy Intro and Help
Ramstein Air Base, Germany via California
Website
www.myspace.com
Hey guys, I'm Kevin and just bought a 94 Land Cruiser a couple of months ago. This our first LC and won't be our last, since my wife has fallen in love with our 80, she drives it more than I do. I'll post some pics and info in the registry once it stops raining here.
Now for the help, just the other day our LC decided to throw an engine light. I checked the code and pretty sure it was code 7, Throttle Position Sensor. But just in case i read the code wrong here is a video of it. YouTube - My FZJ80 engine light code
now what should i do to fix it? does it need to be replaced or does the TB just need to be cleaned?
Thanks
Kevin
Looks like code 71 to me - but its been a while.
Looks like a 71. Search for that. Pretty sure that is the EGR system. Check the EGR modulator. Vaccum tubes for carbon buildup. Test EGR modulator while at it. There is several other things too. Searching for 71 if that is what it is you'll find plenty of help.
Cool vid! :)
Definitely code 71.
Curtis
X2. Thanks for the video. I've read about the procedure for pulling the codes on OBD1 trucks but hadn't seen it done before! I counted 7 flashes then a pause, then 1 flash and a pause then it loops again. 71 it is!
my 94 just had a 71 code.....the egr passageway through the intake manifold was clogged on mine (very common problem)...it clogs up with carbon
right behind the throttle body where it makes a turn downwards into the manifold...
if your egr will hold vacuum and the truck won't stall or stumble when you apply vacuum to it, then you can be sure that the passageway is plugged.....if not it could just be a dirty temp sensor that is giving the code.
do all the fsm tests before you start replacing parts...
good luck..
Kevin,
Cool video. Code 71 on the pre-OBD trucks indicates a problem with the EGR system. The early trucks like yours are less problem-prone in the EGR area but they still can have problems as you see. Start with the simple stuff; cleaning the EGR modulator, checking all the hoses to the EGR valve and the EGR modulator. If that turns up empty then start looking at the other threads on Code 71 (Advanced Search, 80-section, Keywords=code 71* (maybe with "EGR" as part of the search.) Let me know if you have problems with the SEARCH and I will be happy to help.
If you still turn up empty, start with the P0401 codes that the later models have (that is an OBD-II code.) There are hundreds of posts on how to resolve the P0401.
Keep us posted on your progress and welcome to 'Mud and to 80-Series ownership.
-B-
Didn't I say the same thing in a totally non tech way :P
You did, but we needed 3 posts with good advice to out-weigh the posts with bad advice. :D
Seriously, I know that I am being harsh but irresponsible responses to new guys is just plain wrong. The OP stated that he was new to the section and he doesn't know one guy from another... we all hold equal credibility to a newbie and telling someone to go out and buy a new TPS without getting a bit more information is bad advice. The OP was not reporting any driveability problems or any other problems... just the MIL.
Even Dan hates to see guys wasting money on bad technical advice and he has dogs to feed. :D
-B-
Thanks
Kevin
Bienvenido!!! = Welcome!!! My wife does the same, she drives the Cruiser more than me.:D
The EFI fuse is a standard (AGC ??) fuse you can remove with your fingers or one of those plastic "pincher" tools or needle nose pliars. It is not at all 'pesky' and is quite easy to remove. The EFI fuse is located in the fuse box under the bonnet, aft of the battery on the left side of the engine bay.
-B-
Maybe you should post up a picture. I have pulled mine a dozen times and it just pulls straight up and out of the holder. I am not aware of any tabs on the fuse.
Are you talking about tabs holding on the top of the fuse box?
-B-
