new engine no life
We just replaced a frozen engine in a 91 FJ-80. It was running great but on the third day after driving to local market it would not start. Checked all the fluids, plenty of battery juice. Sounded like no fire or no getting fuel. We replaced the igniter and coil with one from a neighbor and it still has no spark. We used the distributor from the fried motor on the newer one. In addition we put new cam gear in beacuse the gasket at the crank pulley was leaking, new distributor cap, spark plug wires etc. All oem parts. We checked all fuses and relays still no spark. Can't check the fuel pump pressure without spark.
Any ideas? thanks.
Disclaimer... I'm not a mechanic.
Where are you at? There may be someone local that can help out or at least stand around drink beer laugh and point.
It sounds like you need to cure your spark issue first then move on. Walk through it.
From your post I'm assuming that the engine is turning over when the starter motor is engaged, but isn't catching?
Do you have spark at the stator wire?
Grench - Wichita falls. Yeah, primary side, no spark. The mech who repalced the engine going to open it back down to the distributor. I'll post what he finds. Thanks for the reply
virtual mecahnics - no spark no fire
the solution to the no spark/no fire on a newly replaced engine in a 91 80 was indeed the EFI relay. There is agood post in the technical links that describes how to fix it, appears it was a factory problem - carry a spare
To those who diiagnosed -this muchas gracias.
