- Joined
- Jun 6, 2005
- Threads
- 80
- Messages
- 1,498
- Location
- Jacksonville Beach, Florida
- Website
- exitoffroad.com
Sharing the news on these new products that Dobinsons seemingly pulled out of nowhere!! These are the newest additions to the 3-Way Adjustable MRA Shocks that Dobinsons have had for quite a few years, and these are called the Smoothie Series. Referring to the zinc plated DOM 3mm steel shock body for ultimate corrosion resistance and strength, these things are smooth to the touch for sure, while the reservoir is not!! The new 10" long aluminum reservoir is finned from one end to the other, with a diameter of 64mm for maximum cooling of the internals and oil. And of course you can still adjust the High and Low Speed Compression as well as Rebound, making these 3 Way adjustable shocks quite possibly the most tunable on the market. There are also numerous length Smoothie coilovers, we'll put that up in a separate thread, as this thread is for the shocks only.
These are the 3 lengths now in stock and available here in the USA. Click on the title of each for pricing, full details and more photos:
Here are the features of the Smoothie MRA shocks available now:
- MRA92-A2520 – 10″ Travel Shock
- Extended Length: 29.45″ / 750mm
- Compressed Length: 19.48″ / 496mm
- Reservoir Length: 10″ / 250mm
- Hose Length: 19.6″ / 500mm
- Rod Diameter: 22mm
- MRA92-A2522 – 12″ Travel Shock
- Extended Length: 33.42″ / 851mm
- Compressed Length: 21.48″ / 547mm
- Reservoir Length: 12″ / 300mm
- MRA92-A2524 – 14″ Travel Shock
- Extended Length: 38.49″ / 980mm
- Compressed Length: 24.0″ / 611mm
- MRA means Monotube Remote (reservoir) Adjustable
- 3-way Adjustable shocks provide maximum adjustability to provide the perfect ride quality for you.
- 10 Stage High Speed Compression – For aggressive, high speed off roading through ruts and holes.
- 20 Stage Low Speed Compression – For creepy crawling and cornering
- 15 Stage Rebound – Control your coils, prevent bucking
- 5140 HV900 Hard Chrome Plated, Heat Treated 22mm micro-polished high strength shock shaft.
- Shaft minimum tensile strength exceeding 700MPA / 100 PSI and hardness exceeding 46HRC
- 2.6″ Shock Body precision honed to +/- 0.04mm
- Zinc plated DOM 3mm steel shock body for ultimate corrosion protection
- Parker Steel braided, rubber coated high pressure hoses
- Lightweight CNC machined low friction floating piston
- 3 Stage FMJ+HNBR long life, low friction sealing system
- PTFE lined high quality spherical bearings
- Fully rebuildable and tunable
- Dual rate design with high quality slider & cross-over rings
- 64mm Finned Aluminum Reservoir
- 350V.I. High performance damper fluid
- T6061 CNC machined ultra high flow race piston
- Includes universal reservoir isolators and hose clamps
- Replacement shims and misalignment spacers are included
- SINGLE SHOCK INCLUDED (Add two to cart for pair)
- WARNING PLEASE READ this notice about misalignment spacers
- Fully detailed guide and owners manual – MUST READ before ordering to understand setting up the shocks
