So after hating the usual speaker mount options for the FJ40 I decided to build my own.
I wanted the housing to be able to take a 6.5 in speaker instead of the 5.5' that were in my 40. The 5.5's were not enclosed and were mounted to the back tub wall.
I made a prototype in cardboard then drew it in Fusion 360. The new design has feet so it will sit above the ridges in the bottom of the tub and sit over the nut for the roll bar mount.
A 10mm bolt drilled through the box holds it in place into an existing threaded hole on the back wall.
The angle is so the drivers side speaker faces the passenger and the passenger side speaker faces the driver instead of facing the jump seats.
I also designed an air vent for the speaker to allow better movement of the speaker cone. I also put poly fill in the speaker boxes.
I know the color is not a perfect match but I think it works. Let me know what you think.
