NEw Dash
mine was also hacked up bad. so i just did this real quick
I found a 48x30 that is about 1/8 thick or so sheet of 5052 aluminum for about $30 in oklahoma city at a metal supermarket store. Any metal shop is going to be about half as much as home depot or lowes. I fabbed a new gage panel that fits over the old panel for my new gages. I saw a design on the internet somewhere, and made my own model of it. I used a bandsaw to rough cut it and a mill to cut the holes. It is pretty easy, so any shop could do it, but if you are trying to cut an enitre dash out of one plate, the mill I used wouldn't work because you couldn't rotate the whole sheet around the base of the machine. Maybe there is another way, I'm no machinist. You could try to cut the holes with a jigsaw and then grind the holes smooth. Haven't tried it on aluminum that thick, but i'm sure with a little patients and a few boxes of blades, you could get it done. I'll post pics later when I get home. Good luck.
Zac
i just got the metal at a local steel place. then made the tubing surround. The SS hex bolts are attached to a metal rim that was welded inside of the tub surounding.
painted it looks nice, but i forgot to put a glove box in, so i am working on that part now :D
oh, the sheet metal was cut with a 4.5" angle grinder with a cut off wheel, if you have a steady hand, you can cut nice and streigh.
shane
Zac
If i were you i would use a air grinder or a hole bit made for steel. Aluminum is really soft so it wouldnt be anything to cut. Then get some emory cloth and clean it up. Also Make sure you put a gasket between the steel and aluminum and use stainless bolts for protection against electrolsis (spelling?) between the two metals. You can get some inuslator between the two. ;)
If you're going to use aluminum cover plates, all you have to do is attach the plates to your dash with 1/16" two way foam tape. The tape is the insulator. I also put nickel size beads of acrylic latex caulk between the tape to insure bonding. The aluminum I used was 1/8" thick. After I cut it, I used a belt sander to straighten and smooth the edges, and then put a bevel on the edges to try and match the stamped edges of the stock dash. The beveled edges made it fairly easy to run a smooth bead of caulking around the exterior.
Oh, and the air intake holes on the aprons are stock on a FJ25. Well, the driver side is. I added the passenger side since it's a 350. It works great, even at 85 mph.
