That's very reassuring to know. Your cat is CARB compliant? What viscosity are you running?Absolutely. I put a CAT even on my pre CAT LCs to cut down the stink. I know CA Catalytic converters are now around $1200 for a CARB compliant one, but still cheaper than engine repair.
The Rotella is excellent oil and will be easier on your CAT, just wouldn't go past 3K miles on it.
Btw, when zddp was plentiful in oil, CATs were expected to last 100K miles. Now they want them to last 150k with lower emissions.
I'm not worried about it.
Does Rotella being labeled as a diesel oil bear any consequence?
Regarding your earlier statement on ZDDP being consumed by the engine, have you seen any data on the level of consumption? I thought synthetic oils do a much better job of retaining the effectiveness of chemicals, thus allowing long oil change intervals on modern cars.
The main reason I looked for historical data is because I figure if I get back to historical level of ZDDP, nothing more, nothing less, I would expect my cat to tolerate it to a reasonable extent. Of course, I'm not sure how much California spec cat has changed over the years.ZDDP levels were reduced as the API specs changed, i.e. the SJ, SK, ... SM, SN etc... Mostly because of Federal Regulation. One had to read the 'Star Burst' label on back of the bottles for the proper oil - SJ oils (the 1400 ppm zddp level minimum) were common through the early 2000s, then as older vehicles were removed from service, the demand/need for those oils declined. It wasn't uncommon to find old cases of SJ rated oil on the clearance shelves of Pep Boys, etc... I bought a few of those.
The Lucas oil is very good and a fair price, just has to be Amazon drop shipped. Castrol is avail at many Walmarts. At the source link that @Racer65 posted, it says the higher level of detergents (calcium, magnesium compounds ) in long-drain oils interferes with zddp. Again, this is why frequent dino oil changes are best for these antique engines. Amsoil, Redline, Brad Penn, etc are all great oils for a 2F, just expensive... I don't think $130 oil change is necessary. But that's just me.
Key is adequate protection and 3-5K miles oil changes; closer to the 3k if you're using an oil with 1200 ppm zddp, like Rotella diesel.
I have thought about this too since I use LiquiMoly products and additives in my Chevy truck to stave off the dreaded collapsed lifter from build up gumming up cylinder on demand.There are probably modern oils with Moly as the anti-wear agent that protect as well, or even better than zddp, but I dunno. All I can go by is trying to get back to an SJ oil spec, which is what was around when these F/2F engines were shoved into chassis in Japan.
