New Brake Caliper thread
Overland Park , Kansas
i did a quick search and didnt see anything recent on caliper replacement .
from the old threads i read it looked like these were the options
Toyota Reman from Beno
Napa Reman
Centric from Rock Auto
anything else to consider recently?
im getting ready to buy new calipers and LSPV Valve
thanks in advance
I got mine from R1 concepts
so i think i will go with the NAPA ones, i can get them in a day locally no shipping .
what about any of the Valves? think i should put new ones in while the calipers are out?
I got calipers (front only) from Napa a couple months ago - seemed ok, nothing obviously wrong, and they seem to still be working fine too. My main motivation in using those was that they were the only ones I found available in stock locally and I didn't want to mess around shipping the old ones out to get the core charge back. Also had read some reviews here or elsewhere that said they were ok.
what do you mean "valves"? as far as the napa calipers I just put all 4 on my cruiser, back in October I finished up that plus the two main brake lines from the lspv to the front, and all the soft lines front and rear too. I thought the napa calipers had a great finish on them, but one had a slightly chewed up piston, and they got me another in the next day....so far my brakes are working great
i think there is a rear proportioning valve and the LPSV. someone else told me i should change the brake lines also .
i have new stainless steel ones from the caliper to the steel line , i flushed the brake fluid and lines when i did the brakes 8k miles ago. but i never looked at either of those valves.
i guess i will just see what happens when put the calipers on
i have new stainless steel ones from the caliper to the steel line , i flushed the brake fluid and lines when i didn the brakes 8k miles ago. but i never looked at either of those valves.
I think the lspv is the proportioning valve, its the only one back there, and I was under my truck for a damn month replacing those two long lines a little every day after work. my lspv was ok, a lttle crusty looking but wasn't leaking and after soaking the bleeder in pb blaster while I worked on the rest of it[had to remove gas tank straps and guard and slide tank over to be able to remove the bolted clamps for the two long lines from the lspv to the front] [was no fun by myself in my driveway I tell ya] my lspv bleeder came out and I replaced it with a new one, [not available separate from Toyota] but I got a decent one from napa, but the nut "size" is smaller than oem, no biggee but when bleeding remember to have a 8mm flare wrench[factory is same 10mm] as well as a 10mm for the calipers
I think I priced a new lspv at around 214$ from Toyota and since mine wasn't leaking and I was able to bleed it properly I just ran with it
you are from new York, east coast like me......check along the frame rail where those lines run from front to rear and there is a clamp that has rubber holding the lines towards the front of the frame rail, mine had trapped water and rusted one of the lines right in that rubber clamped area, so I pulled them both and replaced them plus a bunch of the steel lines on the front and rear axles
yah for sure i will check , did you buy premade lines form toyota?
I did my front soft lines.
Took about and hour apiece to remove, put them on the next day (These trucks make great 2nd cars :)).
If you buy the Napa ones they were made by United and were made by same company as Raybestos, it was clearly Chinese.
All the ones I bought were just rebanded Chinese parts. Time will tell how good they were. Sourced from RockAuto.
I used heat and PB blaster to get mine loose. YOur wasting your time with a 2 sided wrench, but a Channel-lock did the trick. I heat each connection ~4x before they broke loose. Cleaned them use with a brass brush using bench vice then blew off with compressed air.
Spraying lines/connections with Fluid Film will go a long way in making them last.
If you have time buy a flaring tool and EZ Bend Tubing.
Skills last for life, and so will that line.
yes , I am running stock height so I used the soft lines[ I tried soft lines from napa but they were made wrong and the clips that slide on and fasten them to the brackets wouldn't go one so I returned them and just got all 7 from Toyota] AND the factory hard lines from Toyota, the hard lines were a "little" bent up but I managed to pull the old lines in one piece so I laid them out in the driveway and straightened the new lines to go on , also ordered new plastic clips that snapped into the frame towards the rear[I wish all the fasteners has been plastic, as the only rubber clamped one caused the line to rust through]
I bet I visited my local Toyota parts guys a dozen times cause every time I went under the truck[original repair was rear calipers/rotors cause an original 20 year old rear caliper froze up and killed a rotor] I found something else corroded or froze and needed replaced so its all new and working great now.
